[CASE] Phanteks Enthoo EVOLV ATX
*adiBOY
A box within a box
Sent from Pillars of Creation using GAGT
Nice! They kept their coloured box. How much did you pay for it?
MicLimHS
For my Enthoo Evolv ATX Tempered glass, i can't seems to find my Reset connector
also the LED don't seems to light up as well.
Anyone faces the same issue?
souler87
For mine it only have the power switch n the HDD led? Led is the one for the front panel? I'm was thinking how am I going to change to the red led included.
The internal black paint also easily scratch off so for those need to change the motherboard standoff do take note.
MicLimHS
What? Got problem ah. I haven assemble my com leh. U got Google the problem?
Tried googling, but no info. the case too new?
Possible to check you chassis tonight?
see if you can find the Reset connector (the one that hooked up to the motherboard)
Yea, my chassis only have the Power and HDD LED connector.
Missing the Reset connector,
also how do you turn on the front LED? the one at the bottom of the front panel's LED?
Is there a connector for it?
*adiBOY
This case isn't new. They just changed the side panels to tempered glass. If you really cannot find, call Corbell and they will assist you. There is a 2 year wan try for this case.
I am going to assemble tonight. Will post here if anything is missing.
Gloom me
For my Evolv ATX, which I guess should be the same as the tempered glass version, all cables are there bundle together. Shouldn't have miss it unless it's really missing?
Power connector should be for the front panel LED.
MicLimHS
Yea, gonna give Corbell a call.
Anyway, if in the case of warranty..
Do i need to bring down the case personally, or they will deliver a 1:1 exchange?
Thinking the need to lug the case around send chills down my spine, :s13:
[edit]
Something i notice is that, this version supports the Enthoo Luxe LED connector?
[/edit]
