Ceiling Fan Recommendation
hkchew03
How is it so far? Maybe I use for balcony. Haha! Break probably hit neighbours
3 months so far so good except 1/5 is wobbly at high speed, but that specific piece was said to be lost and then later delivered to me again 2 weeks later in a semi damaged box. So im blaming it due to that rather than the product as the other 4 pieces were perfect so far. Balancing the blades didn't make it better, no crack or anything wrong found, at least it still work up to speed 3 of 6.
One of the issues with modern ceiling fan is the RF module seems to give way earlier than the PCB/motor, and replacement with labour from manufacturers are usually 2/3 to 3/4 the cost of a budget fan (Fanco etc).
*Fan is one of the controlled goods that require safety mark
LIN_JOEL
Anyone use this fan from kdk? In JB is only $350. Knn’ cheapo than all these unknown brands
https://www.kdk.sg/shop/ceiling-fan/120/e48hp.html
$350 RM so cheap???
I bought the one with LED light @$890 RM and it's a Panasonic cos KDK dun have the color I want.
SG and MY colors offering is difference and KDK / Panasonic under same company in MY...
Free ceiling bracket & Delivery charges to SG is 30RM/unit + GST.
elvintay07
Suspended
$350 RM so cheap???
$350 sgd. good or not huh the quality,
Aero_GT
$350 RM so cheap???
which shop u buy from?
LIN_JOEL
https://www.kdk.com.my/product/k12uc/
https://www.kdk.com.my/product/k12yc/
With light and no light.
Why urs $350 SGD with no light....more expensive than RSP....
JB Tampoi might be cheaper but I get from YES Supply Electrical (Near Pelangi there)
U can fb them for pricing, their boss, an old uncle is very chatty and helpful.
This fan got reverse air circulation function but read one post saying the wifi is not good because their apps sux.... yet to install mine.
LIN_JOEL
YES Supply Electrical.
Bought from them 3 times, I will pm them asking the stock and price and confirm before I go down.
My last purchased I got to know they actually provide delivery and save me from self carry.
elvintay07
Suspended
Got any other brands? Singapore got many brands like Aeroair, Bestar, Point technology, Alaska. Why Malaysia don’t have? Because KDK and Panasonic too cheap?
LIN_JOEL
Maybe because KDK/Panasonic is a long time reputable brand?
Or maybe got the mentality that I can save more while getting the same thing except for its warranty coverage.
Perhaps you can go their FB see what they got or try pm them.
I got my LED lights and Legrand Switches from them last time.
elvintay07
Suspended
In my humble opinion, don’t need to waste time buy from SG. After my intensive research (both ceiling fan and lights), most local sellers don’t know much
(1) Ask them specs. They will tell you no one use specs one. See box ok alresdy
(2) Ask them how to install. They say they not contractor. One shop I went lagi worst. They said if your contractor don’t know, can come ask me. Lim peh go teach them. But I don’t teach if you don’t buy.
With this kind of attitude, you think you got problem they will help you? I think wait long long. Hence
(1) get cheapest deal (Malaysia) or taobao
(2) get solid solid contractor
hkchew03
Can I know who helped you with the installation?
I am also keen to get from taobao but need some help with the installation
DIY or just get handyman, smaller one should be about $40/fan, bigger one up to $80. Once again, neither seller nor the handyman will take responsibility if anything happen. It just the risk from getting electrical items oversea.
