Ceiling Fan Recommendation
LIN_JOEL
Typo. Should be who instead of you. Maybe I buy Panasonic/ KDK from Malaysia. I realised kdk doesn’t have 52-60 inch. Not sure whether 48” vs 52” will have lots of difference
I have 2 to 3 Brand New 48" Panasonic to let go if you're interested.
Cos wife dun like ceiling fan under bed, so have to find ways to clear it......zzzzz
elvintay07
Suspended
SG one ah? I not looking for fan now but my friend maybe. Maybe pm you number and I ask him to contact u
ZacharyA
don't bother, bladeless fan is way less powerful, not suitable for SG environment unless you using it with AC.
I agree, even the Dyson fan AM dunno what is not as powerful as a standard ceiling fan. And if you use fan speed 8-10 it is so freaking noisy like using a hairdryer.
elvintay07
Suspended
Hi all, am shopping around for ceiling fans and corner wall fans. Any thoughts or existing users of the following options? i dont need it to be smart or wifi-enabled. Thank you!
Ceiling fan:
- Prestige M3 52" ($4xx)
- Alaska Fern 56" ($4xx) / Alaska Hydson 52" ($3xx)
Corner fan:
- Alaska Eskye 15" ($3xx - exp!)
- Fanco Dono 16” ($199) - likely going for this
Is prestige m3 only $400+? I thought it comes with smart home features. $400+ seems very reasonable
elvintay07
Suspended
Anyone using PO fan here? I look at the design quite nice (similar to m3). My friends bought haiku for living and dining and bedroom use all PO fan. Seems like quite stylo from internet.
marcoyeo
When I visited ceiling fan demo section of retail store like Courts, the SA recommended me Fanztec. I also checked out Mayer whose distribute Mistral D'Fan series hugger and non-hugger.
In the aircon retail mall, usually i can't tell if they are suitable and meet my needs. I just need one to have sufficient wind speed/circulate the air in my HDB BTO 2x bedrooms and 1x living room. I also need a LED min. 20W daylight 5500~6000K temperature will do. I find it hard to look for one. Not sure anyone share same dilemma like me. But I do need to get them in 1-2 months time for my family.
elvintay07
Suspended
I feel very difficult to tell. Theoretically you have to mount in a room where there are obstructions like lights, cabinets etc. also fan is about windy directly below. The sides are ok but not super windy and won’t work if that day is super hot and humid. I think you need to pump 1-2 hours aircon then let fan take over for next 4-5 hours. Personally I haven’t find my perfect fan. Likely go for design and will buy those like prestige, point technology etc.
marcoyeo
Just share my experience after 1-2 months of light search. I actually gave up trying demo already. I just went online to read reviews and check the specification like rpm/watt/features.
Ended up.. I bought Bestar ones during 6.6 sales and installed yesterday. Their LED at 24W looks bright enough and sufficient for my bro layout/size home. Since function and price remains one of top criteria, design is ok with 3 blades, simple looking fans. The remote control has last memory feature, easy to use.
qhong61
How much
