[CONSOLIDATED] Air India plane crashes at India's Ahmedabad airport
Dopod007
The 2 fuel switches moved to cutoff in about 1 second, one after another.
Wonder is that possible with 2 spring loaded switch that requires lifting up before moving it.
The PF (pilot flying) will be too busy as flight just lift off. The PM (pilot monitor) has the time to do it though.
Wasn't stated who is the PF and PM in the report.
Or maybe the resolution of the timing is rather coarse, eg 1.9 second is logged as 1 second dependent on the sampling interval ?
Take note that recovery action (by pilot/or pilots) had been initiated to restart both the engines but there wasn't enough time for the engines to develop sufficient thrust ...
Possible for the pilot who cut off the fuel to both engines is suicidal. So it was done on purpose to kill himself and everyone on board...
Teyemittisi
Maybe pilot is a free loader and not really skilled .. or he wanted to bring down everyone with him
tmkedmw
If true, this is call murder-suicide cos planeload of crew/passengers perished too.
Case becomes criminal and certain conversations in the voice recorder will not be disclosed as a criminal investigation will proceed in parallel with the incident investigation by AAIB.
PaprikaSG
Obviously is Sia n Singapore fault ...
lalalalalala
Saw this video saying both were in the off position. This rules out accidentally cut off wrong one
Avant-Garde
Hypothetical scenario of what the youtuber meant
Engine 1 spoil.
Pilot wanted to cut fuel to engine 1.
Screwed up and cut fuel to engine 2 instead.
based on the latest report,
engine 2 shut down 1 second after engine 1.
doubt they could react in 1 second to cut off the fuel to engine 2 and also for engine 2 to stop immediately.
