CongratulationsIirc, there was a news article on SQ taking in 100 pilots from Air India for their budget airline?![]()
I make the same comment. For all you know it could be the one asking the question the one that switched it off.The pilot make the mistake and decided to lie at that point of time when asked by the other pilot, their culture.
If the pilot admit his mistake on this spot, the error can be corrected.
OK but how can the engines be both simultaneously shut off and also be shut off one after the other?engine 1 & 2 simultaneously shut off one after the other.
This pilot youtuber made a very good guess long before news broke. He speculated that one engine malfunctioned and a pilot accidently cutoff fuel to the good engine.
well, pardon my poor english.OK but how can the engines be both simultaneously shut off and also be shut off one after the other?
Cutoff fuel at that low altitude is gone case liao... cos there is not enough time for the engines to restart and generate thrust needed to avoid crashing to ground.The pilot make the mistake and decided to lie at that point of time when asked by the other pilot, their culture.
Means is something like reflex when they cut the engine. Cutting off both together at the same time. I assume there's fail safe mechanism whereby need to do 1 at a time therefore having the slight delaywell, pardon my poor english.
it was 1 second apart, so i guess 'almost' simultaneously seems more appropriate.
I read the article. It say pilot 1 told 2 why cut off. 2 deny.Think can only guess, no way to know unless the pilots specifically said it out at that time
Saw this video saying both were in the off position. This rules out accidentally cut off wrong one
Hypothetical scenario of what the youtuber meant
Engine 1 spoil.
Pilot wanted to cut fuel to engine 1.
Screwed up and cut fuel to engine 2 instead.
Maybe they thought it's the landing gear button...What’s the reason that he cut off the fuel is impt.
