The CPF Annual Limit for an "all three account" contribution is $37,740 to be precise.
Sorry, no option. The contribution is allocated according to the rules for your age and including your MediSave Account's Basic Healthcare Sum limit. If you're age 54 and make a voluntary contribution of $37,740, here's how it'll be allocated:
MA: ~$8,000 (to top it up to $60,000, the 2020 Basic Healthcare Sum)
SA: $11,729.59
OA: ~$18,010.41 (the MA portion above the Basic Healthcare Sum spills over into your OA since your SA has already reached the Full Retirement Sum)
A bit of advice, though: you're better off making a MediSave contribution first followed by an "all three" contribution. The total of these two contributions should be $37,740 or less. You get exactly the same result in terms of balances, but just in case you have enough taxable income in 2020 (Year of Assessment 2021) you'll get tax relief on the MediSave portion. For example, if you decide to go back to work (family emergency?) and/or have taxable rental income, you may get some tax relief. It doesn't hurt to split this up into two successive top ups and might help, so you might as well do it that way.
Yes, that's right.
For the MediSave portion, as soon as immediately, if you have a MediSave payable medical expense.
For the rest, as early as age 55. You already have plenty of dollars in your OA+SA to fund your Retirement Account to the Full Retirement Sum when it's created on your 55th birthday. Consequently all dollars added now to both your OA and SA can be withdrawn at age 55.
If you want to withdraw dollars from your Retirement Account, this top up may reduce the maximum amount you can withdraw (with a sufficient property pledge or charge). If you don't plan to withdraw many (or any) Retirement Account dollars, or (better yet) if you plan to boost your Retirement Account above the Full Retirement Sum, then this particular detail doesn't matter.
Via CPF Form MHC-TRF, yes. Please note that the transferred funds would be drawn from your spouse's Special Account first, and those funds are earning at least 4% interest too. So it doesn't generally make sense to do this.
However, I can think of one situation when this might make sense. Let's suppose your spouse meets all the following conditions:
(a) Under age 55;
(b) Has a Special Account with a balance that is a little above the Full Retirement Sum, or less than that amount; AND
(c) Will have taxable income in 2020 (pay income tax in Year of Assessment 2021).
In this case, she could transfer Special Account dollars to your MediSave Account, then top her Special Account back up to the Full Retirement Sum, with tax relief. If her Special Account is at or below the Full Retirement Sum, then up to $7,000 of tax relief is available this way. If her Special Account is slightly above the Full Retirement Sum then the two of you have to do a little extra calculating.
You would still have the $37,740 that you can top up, and (with your MediSave Account full, or fuller), more or all of that $37,740 would flow into your OA and SA.
Unfortunately there's no MediSave-to-MediSave transfer available between you and your spouse, but you can pay each other's MediSave payable expenses, as you prefer.
If I need to explain this particular maneuver in a little more detail, please let me know.
Thanks so much for taking time to write this reply. Ok, xfer fr my spouses cpf does not gain any advantage since her SA is higher than FRS.
Now, her MA is now 59K n she is working. Can she cash top up 1k, n then claim tax relief? Or she can't since she shd probably reach the limit v soon with her employer's contribution ?
