Creative Outlier Air truly wireless earphones
Vulpix
Moderator
Moderator
I finally tuned my Poweramp EQ properly for this earphones, feels good man.
Vulpix
Moderator
Moderator
When I tried the Outlier Air once connect it auto AptX d. I tried another creative speaker with AptX also auto. But when I try Sony 1000XM3 no auto also don't let me set AptX. No idea what's wrong there haha
I'm pretty sure Sony doesn't use AptX.
thumbtacked
Anyone found replacement eartips that can fit into the case? I need bigger right side eartips.
This is one shortcoming of this set. Even $20 China ones got 3 diff sizes.
Edit: does any shop in SG sell comply foam tips for Jabra elite 65t? These look like they will fit.
ckfreeblue
Have the same problem as you. Tried a few other ear tips. They fit into your ears but do do not fit into the box when charging. Because of this I’m returning my set.
tmxgkh
My left ear bud suddenly stopped working as well (no led light, Long press produces a sound), was working fine this morning:s13::s13:
Performed a master reset now both buds not working (right bud still has light but both cannot connect/find on the device)
Creative if u are reading this... please improve ur QC ahhhh
you going to their service center or they just gna send u new one?
bobaccord
Sometimes I borrow my wife IconX to listen to music and watch movies. The 2018 iconx is pretty good. I wonder if the outlier air is as good as that?
Sent from Samsung SM-N950F using GAGT
kennyboy
You need to change some setting in the Sony Headphone app iirc. The lesser quality option, otherwise it will use LDAC.
Cometdevil
I just notice I order mine online way before the computer show. But my delivery is scheduled next week. That's a long wait..
kennyboy
QCY which model? T1? Before CNY saw it on offer $19.99 didn't pull the trigger :D :D Next 2 day see out of stock d.
Now using Indiegogo PaMu (first gen but BT5.0 revised version) and ERL2.0.
ERL2.0 normal usage outside will intermittent dc from left to right but maybe 1-2 times per hour only. Last time use PaMu first gen BT4.2 use till vomit blood tio freezer then spoil and request replacement they sent me BT5.0 revised version. Still not 100%. ERL2.0 has more solid connection than Pamu first gen BT5.0 version but it came almost a year after order as their first version is 9999% bad. Heard the newer PaMu Scroll perform much better but now that Creative comes out with Air, PaMu Scroll current post campaign price on indiegogo totally not worth it. Better get Creative :D. Tried the ERL2.0 at IT Show today inside the show really CMI keep DC. But lucky normal transit use it's almost perfect. It has better fit so I think I'll hold off buying Outlier Air first. Wait for next round promo? Haha
Actually the QCY T1 is pretty good for a budget TWS. It does many things similar to the Creative at a fraction of the cost. For those on a budget, can consider it.
TheOutsider
Think it's quite normal for such master/slave configs. :s13:
But in case of Jabra elite 65t, I noticed that the right headset is about 1g heavier based on their specs. I guess they compensate for the power consumption of the Master unit by having slightly bigger battery in it.
Not sure if that's the case :D :D
