My review so far
The good,
Sound quality closely resembles the outlier one plus
The earphones very secure, did not shift during jog
Even when sprinting did not fall out, I was still worries may fall
Very shiok without wire, when jogging no wire, controller tug, hitting your face.
Very comfortable without anything on yr neck.
Sound isolation is good
Must have for gym and jogging.
Price wise at $99, I would say value for money.
If you are looking into high quality sound when doing sport, then of course you need to buy others brands.
If you are focusing on yr sports and don’t mind a not bad sound quality, this is a buy.
The bad,
Left earphone suddenly no sound when jogging, work fine after re pairing
Hope it’s a one off glitch.
When paring with iPad, it’s show connected but appear another prompt say pair headphone?
If you click ok, you end up with another Bluetooth device headphone, which is weird.
Click cancel instead
Press and hold to turn off and on volume hard to control to turn one notch up or down.
The case led.
From what I see,
L and R blue means charging the earphones, the earphones battery is more than 30%
L and R red means charging the earphones, the earphones battery currently less than 30%
The battery indicator light blue when open means the case battery more than 30%
The battery indicator light red when open means the case battery less than 30%
The charging led blue means charging case battery, more than 30%
The charging led red means charging case battery, less than 30%
The L and R and charging led not lighted means fully charged.
