Curved OLED
orhanzi
My LG logo light does not turn off when I switch off the main power. Sometimes it stay on for 5-10 minutes and then the lights turn off.
Sometimes, the logo light cut off immediately with the tic-tak sound when I off the main power switch. Anyone here got the same problem as me?
after main power off, the LG logo will be still on for 5-10mins. i still have yet encounter immediate light cut off. when LG logo still on with main power off, if use remote to try to power on, there's a tick tak sound though.
mrsun18
That's the reserve from the power supply capacitor.
antsig30
Yes. I have try the same before and got the same thing. For my case, the logo light is random. Sometime it will stay on for a while and sometime cut off immediately.
I got another issue with the power button. Sometimes I need to press the power button twice in magic remote to turn on/off the TV. Initially I thought I got a faulty remote and change a new set with LG. Seems that the new remote have the same behavior. I got a Logitech harmony remote control and encounter the same problem. I suspect problem with my TV IR sensor.
Anyone got this issue?
orhanzi
think your ir sensor gt problem
Shades
Need help... trying to calibrate the EC930T using the Android THX Tune-up.
When I connect using my Nexus 7 -> Slimport -> HDMI -> TV, the TV can detect the HDMI input (shows PCM status) but basically nothing is projected from the tablet
Is it my HDMI cable issue (using Sony Hi-speed cable)?
5star_pundit
That is good to know Bro! Even I got worried.. today is the last day for 1 to 1 exchange in case there is any problem with my TV... So hopefully nothing comes up after today.. :)
Can anyone advise me on the proper picture settings for this TV (EC930T)... I cannot seem to get the best setting for color, sharpness, contrast, etc. Are you guys using one of the Presets like Cinema, game or something? Also I remember seeing something about the trumotion setting... But I cannot find that comment now.. Can anyone advise on that? Thanks Guys! :)
i saw the trumotion setting is at ISF pro 1 picture mode.
Strange ,i don't see any truemotion setting in my oled. Maybe trumotion only applies to LCD tv for gaming.
the illuminated LG logo can be turn off completely using one of the settings
alprakas
Damn it, I just did a LCD screen test for dead/bright pixels.. Looks like one of the red pixel is dead.. My TV was delivered last Thursday, and they said within 7 days they will do an one-2-one exchange.. I try calling them tomorrow.. hopefully they can change it .. otherwise damn! big heart pain!
alprakas
https://www.avforums.com/threads/lg-55ec930v-reviewers-recommended-best-settings.1922378/
Picture Mode:Expert 1
OLED Light: 57
Contrast: 75
Brightness: 41
H Sharpness: 10
V Sharpness: 10
Colour: 50
Tint: 0
Aspect Ratio: Just Scan
Expert Control
Dynamic Contrast: Off
Super Resolution: Off
Colour Gamut: Standard
Edge Enhancer: Off
Colour Filter: Off
Expert Pattern: Off
Gamma: 2.4
Picture Option
Noise Reduction: Off
MPEG Noise Reduction: Off
Black Level: High
Real Cinema: On
Motion Eye Care: Off
TruMotion: Off
I did try this setting, however i noticed some subtle white areas on a full black image, i think some setting need to tweak to solve the issue but overall this setting is pretty good, good black with good saturation.
Thanks Bro.. I will try that.. But now with this dead pixel thing.. I am not sure if they will replace for just one red dead pixel! I sure do hope so..
ladiesman217
http://www.lg.com/sg/support/warranty/warranty-consumer-electronics
LCD displays typically contain a small number of pixels that do not function normally. Your display has been inspected and is in compliance with manufacturer's specifications, indicating that any pixel defects do not affect the operation or use of you applicable to display. Without prejudice to generality of the foregoing, Dead Pixel not exceeding 7 dots is within factory specification and is not considered a defect under this warranty.
alprakas
Whoah! That's unlucky! I have used, don't know how many monitors in the past.. Luckily not even one of them had a dead/bright pixel problem.. And such an expensive TV kenna one dead pixel! I will still try to call them today.. Let's see what they say... Thanks for the information Bro!
cscs3
Basically this is a very old rule left over during aged lcd days. I do not think this is acceptable when you pay a few K for a device.
orhanzi
i figure which setting causes the subtle white area on the screen. its the black level setting in the picture adjust mode, i set to high, the white area appear, doesn't give me a perfect black screen in a dark room. when this is set to low, i get a perfect black color screen. so weird.
without tweak, the out of box cinema mode default setting is quite good imo.
alprakas
I called up the Harvey Norman guys and they called LG guys to send a technician to ensure that there is indeed a dead red pixel..
Lets see what happens next.. I will update you guys about that..
orhanzi
anyone using dvb-t2 antenna for this tv ? any problem ? if so , what antenna u guys u using
Henry Ng
Use such high end oled Tv to watch just free to air program is like a bit waste of $. Suggest you get Pay Tv. May be Margon 5.1 antenna.
orhanzi
of cos not, i gt a htpc hook up to watch 1080p movie XD.
anyone know if this set have this function SMART TOUCH CONTROL ? beneath the LG logo, no matter how i touch, nothing appear on the screen :(
