Custom Liquid Cooling Club
XcoldstarX
Calling out to all Hardwarezoners who own a custom liquid cooling loop. It doesn't matter if you have EK, DangerDen, Koolance, Aqua Computer or etcetera. Post your photos here and I will link them on the first post.
This thread will serve to allow liquid cooling enthusiasts to discuss and share their views, show off their hard work and also introduce and guide those who are interested in custom liquid cooling into joining us.
Please post photos and also the specs below it for reference. Thanks!
Members:
1. XcoldstarX (CPU + GPU single loop) link
2. Phallic (CPU single loop)
3. fantasyrulz (CPU single loop) link
4. terence52 (CPU single loop) link
5. whoope3 (CPU + GPU single loop) link
6. Mythmaker (CPU + GPU single loop) link
7. ra[g]e (CPU + MB + GPU single loop) link
8. zedane (CPU + MB + GPU single loop) link
9. fatworm (CPU + GPU single loop) link
10. Kalikway (CPU + MB single loop) link
11. lee-turbo (CPU + GPU single loop) link
12. JimmyBoy007 (CPU single loop)
13. 4AGE_BT (CPU + GPU single loop) link
14. jtchoy (CPU + GPU single loop) link
15. TRUECOPPER (CPU + GPU single loop) link
16. kwangkwang (CPU + GPU dual loop) link
17. noctuacooler (GPU single loop) link
18. godot09 (CPU + GPU single loop & CPU single loop) link
19. Kalikway (CPU + GPU single loop) link
20. r104_for (CPU + MB + GPU Single loop) link
XcoldstarX
Liquid Cooling Specs:
EK Supreme LT Nickel + Acetal
EK FC-GTX580 Nickel + Plexi
EK FC-GTX580 Nickel Backplate
Iandh Stealth Reservoir 175ml
Swiftech MCP35X
Aqua Computer Airplex Revolution 420/360 (Can mount 3x140mm fans on one side and 3x120mm fans on the other)
EK Coolstream XT 140
Tygon R3606
Primochill Pro LRT Black
Bitspower Fittings
Worklog here: Rose Noire - A TJ-07 inverted ATX facelift
phallic
count me in
EK cpu block
Feser 360 rad
MCP655
Swiftech Micro Res
:D:D
phallic
ur ek res like got a lot of bubbles
can i have a close up shot?
Do u have anti-cyclone for it? Does the bubbles make any noise in rads?
phallic
http://i71.photobucket.com/albums/i145/fantasyrulz/1fbccfbe.jpg[IMG]
[IMG]http://i71.photobucket.com/albums/i145/fantasyrulz/_MG_3676.jpg[IMG]
[IMG]http://i71.photobucket.com/albums/i145/fantasyrulz/aae963eb.jpg[IMG]
some simple pictures...
next target is to water cool both my [B]6950[/B] :([/QUOTE]
are u using ref 6950 ?? If non ref i think hard to find gpu block for it
wat casing is that??
XcoldstarX
I'm not using EK res. I'm using Iandh stealth res 175. I took the photos before I finished the bleeding.
Anyways, post your photos leh. Come and show off a bit.
fantasyrulz
just found out ek do provide the waterblock i need.. now is to save up and
wack it :(
its fractal design r3 externally mounted rad.. cant mount it inside too squeezy haha
phallic
ok ok
next time will take pic and post :D:D
love wc so quiet and cool
try to wc everything :s13::s13::s13:
fantasyrulz
lol i dont have a dvd rom drive because of the res/pump that occupy both my 5.25 slots infront lol... :(
XcoldstarX
wack it :(
Full cover or GPU core only? Makes a whole lot of difference.
@Phallic
Yeah! Love the silence and the fact that the heat zones are consolidated to the radiator only!
phallic
wack it :(
saw one fellow bot non-ref SLi
too much heat and cant find gpu block end up selling off to get ref gfx lol due to the gpu block
phallic
@Phallic
must get full face block...last time use universal gpu block...got artifacts cos the vrm overheated.
So if using gpu block only still must have heatsink at vrm and fan to cool it so in the end is like lppl.
fantasyrulz
@Phallic
i did found a good heatsink plus gpu but too ex already :(
will be going for pure gpu since mine is not a reference.. not gonna oc it much too.. as long as it is silent when fully loaded im happy :s13:
XcoldstarX
Some of the non-ref cards have full cover blocks.
For example:
Asus GTX580 DirectCUII, MSI GTX580 Lighting, Gainward and Palit GTX580 3GB.
fantasyrulz
did u oc it ?
phallic
For example:
This card dont have - the fellow i am talkin about have 2 of this lol
XcoldstarX
Your Sapphire card model is:
SAPPHIRE 100312-1GSR Radeon™ HD 6950 1GB ?
Oops my bad.
