DBS changed its Mutiplier plan
ThreeSteps
Website: https://www.posb.com.sg/personal/casa-campaigns-landing.page
Maybe they have not upload the new t&cs online.
But based on past patterns, can easily guess the new dbs/posb branch Casa promo starts from 10 July & probably same terms as the previous promo.
For those eager today, can try visit any dbs/posb branch (based on past comments, better bring along ATM card in addition to NRIC)
shengliang1981
I managed to register 2 days ago without ATM card, think just need to sign if did not bring ATM.
point_blank
There was never a minimum for any category but an overall total amount.
Overview of DBS Multiplier Investment Criteria
  • Eligible Products: DBS Invest-Saver (Unit Trusts/ETFs) or digiPortfolio.
  • Minimum Amount: S$100 per transaction/top-up.
  • Currency: You must invest in S$100 minimum value (or equivalent in permitted foreign currencies). A S$100 RSP will meet the criteria, while a 100 JPY investment is much lower than S$1 and will not qualify.
  • Frequency/Duration: Monthly top-ups for RSPs are recognized for the first 12 consecutive months per portfolio/fund
Yet test out but AI says must be SGD$100 or equivalent value in foreign currencies.
cassowary18
Don't believe everything AI says
yiwei
I quote from DBS website, did they say any minimum required for UT or DBS Invest-Saver?
If using digiPortfolio then yes, there is minimum.
AI is not always right.
Unit Trust Lump-sum Investment
  • Valid for new Unit Trust lump-sum or Online Funds Investment purchased with cash, CPFIA or SRS after Multiplier Account is opened.
  • The investment amount will be recognised post settlement date.
Find out more about Unit trust lump-sum investments here.
DBS Invest-Saver
  • Valid for new DBS Invest-Saver plan for Exchange Traded Funds or Unit Trusts purchased after Multiplier Account is opened
  • The monthly investment amount will be recognised for the first 12 consecutive months per fund
Find out more about DBS Invest-Saver here.
digiPortfolio
Valid for new digiPortfolio purchased after Multiplier Account is opened
  • Minimum qualifying amount is S$1,000 per transaction for Lump Sum investments
  • Recurring top ups (RSPs) from S$100 will be recognised for the first 12 consecutive months per portfolio as long as the RSP remains valid
Find out more about digiPortfolio here.
reddevil0728
it's more important to ask if one validated what AI says. seems like many people don't do that.
a4973
DBS Invest-Saver
digiPortfolio
Perhaps you can share the fund's name and your investment method that allows JPY 1 minimum? Thank you
sibeiTrolled
https://www.dbs.com.sg/personal/investments/other-investments/invest-saver
How does Invest-Saver work?​
Invest-Saver is a regular savings plan that lets you invest a fixed sum regularly into your choice of investments, from as little as S$100 a month.
I have yet to find any funds or ETF that doesn't have this min recurring buy in of 100 SGD even if the fund / etf doesn't have any min buy in quantity
Mind posting the fund or etf or stock that you found that suggest otherwise?
reddevil0728
yiwei
yes, need exchange first
You go into funds and filter by currency
I found a total of 4 funds by filtering currency JPY. The minimum investment amount is JPY 100,000.00. Did you mean that you are able to invest in these 4 funds with an investment amount of JPY 100? Thank you
i think 100k if it's one-off. but recurring should be lower but need to have JPY in account to see
You already found them right? not all can, have you exchanged JPY in your account? exchange JPY first, then select RSP, you will see that the min will change to 100JPY.
One of them even allows for direct purchase at 1000 JPY, you dont need to RSP.
For some strange reason, it will only work on the DBS app, not the POSB one.
I have never said it's 1JPY, it's 100JPY min.
Did you try to filter in the app following the above?
sibeiTrolled
Ah thanks a lot. Found it
Brain was stuck in the SGD mode for whatever reason
Now got to fund jpy in the account first... It complaint about not having jpy in my account :rolleyes:
AlvinDj
For digiPortfolio, also need to reset after 12months for Multiplier right?
Just hit my 12th month for digiPortFolio, but there is no tracker in estatement like for the usual UT-RSP or InvestSaver eg. 12/12 etc
Wonder if I can reset it by re-purchasing the same SaveUp portfolio i chosen previously? Or must be different
reddevil0728
Is that what it says in the FAQ? Maybe check the faq to confirm
AlvinDj
Thats the thing.. it says nothing, unlike in the FAQ of the usual old RSP via Invest Saver which clearly states there's a cooldown period of 6months before being able to repurchase the same fund house again..
reddevil0728
Well you can choose to
1) interpret it as it doesn't apply
or
2) get it in black and white from DBS to confirm the understanding so that you have something against them
yiwei
digiPortfolio
Since it says only count for 12 months, I would say buy sth else to be safe. or you just monitor under bank and earn which should be updated after around 4 days after RSP deduction; if it didnt count, do a lump sum with any other funds/UT/digiPortfolio to fulfill the requirement then.
But how do you re-purchase though, cancel the current one and setup new one with same fund?
