Debloating Android phone
Foetid
Now the T series getting more and more expensive. Your 13T and 14T more value for money. How is the batter after 1 year? How many percent left after 1 day usage?
I bought second hand from carousell, if just mini use, or close to standby can probably last 1.5 to 2 days after I debloat.
kevinlaikf
First hand experience with my secondary phone Mi 11T, the phone which i hardly use, it is my "tour-data-sim" phone. The battery last less than 24 hours on a full charge.
After the debloat, the phone can last more than 36 hours without a charge.
helloicanseeu
anyone debloated your android phone?
I used Canta & Shizuku to debloat my xiaomi 13t pro, i find my phone is more responsive and battery can sustain very long time.
Removed all of Xiaomi's telemetrys, ad services, google bloatwares,
After debloating, singpass, bank apps, my corporate work apps still works. 😺
PSA: For those doing, pls ensure you check and google before removal, safer to filter recommended in the Canta list then remove to avoid bricking phone, do not remove critical apps.
small % increase in batt life at most,
need portable battery instead if usage really drains batt while on the move, imo
ads waste time and batt too
helloicanseeu
wow sounds amazing lol
OutBreak
Sounds like bs.
dev_stg_prd
debloat need to JB or simple?
1982-1994
Actually y not just get huawei phones without google services?
using huawei on harmonyOS since August
there are 14 of com.android
and 7 of com.huawei
battery life is good though i charge it once daily because I'm charging from 20% to 60% on most days so my usage is 40% on every charge
adb disabled software update so to prevent from further updates that worsen the battery life (i believed)
uninstalled china apps
CCCustom
This type if and when there is software update, everything is reinstalled back again and you’d need to debloat again, yes?
I bought a Redmi Pad Pro for my kid to use, probably gonna need to do this $#!t as well.
Igene
Debloating really make a huge difference, especially XiaoMi phones. Battery life improve quite significantly.
jeffrey745
and 7 of com.huawei
Wow. Thanks for sharing your experiences. Are u able to use local android apps on it? Which huawei phone are u using?
