Desktop Upgrade Recommendation
ragnarok95
Senior Moderator
Senior Moderator
Before anyone say OH AMAZON NO WARRANTY BLA BLA BLA. I believe every consumer/buyer/first timer here have the right to know what are the available options and decide for themselves.
86technie
Basically below 1k
Not necessary to have wifi
Pairing with i7-11700
Either:
- MSI MAG B560 TOMAHAWK WIFI + i7 11700 - $806
- MSI MAG Z590 TOMAHAWK WIFI + i7 11700 - $876
- ASUS ROG STRIX B560-E GAMING WIFI + i7 11700 - $866
- Asus ASUS TUF B560-PLUS GAMING WIFI + i7 11700 - $770
Add Corsair Veng LPX 3200MHz CL16 16GB - $139 so just nice $1k.
The rest may or may not have stock.
NightRaven49
tradepac has 11700 + gigabyte b560m aorus pro (non wifi) for 682. amazon sg has crucial ballistix 2x8gb 3600mhz for 120 before $7 shipping (eligible for prime). total just over $800.
edit: can also get the 11700 + aorus pro from taobao for under $600 shipping included, but u do lose local warranty support.
b0ib0ii
Thanks Guys, If I have a ATX case (Using Tecware Alpha) now, I dont really need to get a Micro-ATX motherboard right? I should just buy a ATX motherboard?
NightRaven49
well it depends. i would only get atx if i need the extra pcie slots or if it is cheaper. generally atx costs more than matx though. so personally i would just get matx, nothing wrong with putting a matx board in an atx case.
b0ib0ii
I personally would wait for win11 to be out first.
May I know why? haha
Thanks. Will have a look at Matx board.
Just another question, I was recommended a 2x8GB 3200mhz RAM. Does getting a 3600mhz RAM makes a big impact in Frame Per Seconds in game? Or even in usage in using the computer for multitasking?
EDIT: Looks like there wasn't much difference between the 3200 and 3600 ram. But coming from my default 2133 ram bump to 3200. Theres a noticeable difference in gaming. From a post in Reddit.
86technie
Just get 3200mhz RAM will do.
ragnarok95
Senior Moderator
Senior Moderator
For just a few dollars, get the 3600 memory over the 3200 memory. Go for the 3200 only if you have very serious budget issue.
3600 is the sweet sport/ideal speed for both AMD and Intel now.
Kunkka
Does the die still matter?
soulblader_89
I think 650w is enough, but I heard it is better to get 750 watt for future proof, as Gfx card will get more hungry in future
NightRaven49
personally for 650w, at minimum the super flower legion gx pro (not the hx model unless u dont mind non modular cables). very cheap for 650w (~$100 at tradepac), though only 5 year warranty. i dont see its semi modularity as a con since u are going to use the 24pin, 8pin and pcie power anyway, but the 750w and above models include sata power in the fixed cables so i wouldnt recommend them. u can also consider super flower leadex iii, seasonic focus and corsair rm/hx series.
