abstrax
cpu will be ultra 265k paired with rx 9060 xt 16gb, will be planning to do some overclocking for the cpu
only 1 motherboard argb port will be used for the aio, else all the rgb fans will be connected to the nzxt control hub controller
still pondering if to get 850w or just straight to 1000w
I feel go for 1000W straight better in case u wan add more ARGB in the future.
Since u have so many components too eg. HDD, SSD.....is best to get 1000W.
lionheart80
will do, think 1000w is more safer
looking at nzxt c1000 model
spectral
Any recommendations for mb, ram & heatsink to go with 9800X3D?
Will be reusing casing, m.2 ssd, gpu and psu.
NightRaven49
mb - a decent midrange b650 enough, something like the gigabyte aorus elite or asus tuf
ram - not a huge worry for x3d chips, a 6000mhz cl30 kit will be good
heatsink - thermalright peerless assassin for air, arctic liquid freezer series for liquid cooling
these are all minimum recommendations, if u got money to splurge then by all means.
Vanyel
i remember like for the Aorus elite B650M & B850M not much difference in pricing~
bellick
Probably the cheapest component but any recommendations for PC case fans? 😂
Don't really care about RGB, prefer something with less noise
Shahmatt
what size are you looking for? I find Cooler Master or Be Quiet fans to be good value generally.
-Synchronicity-
Thermalright fans are cheap. Specifically the s12.
Taobao sells sets of 1,3 and 5 with the 5 at around 30 bucks after shipping.
DriftKing
Hi all, in preparing for BF6, can I get some recommendations on a rebuild from this? Don't think I'll go 5090, but thinking 5070/5080. AMD CPU? Hope to reuse the case but not sure the restrictions from that.
Processor 8700k - Noctua D15
Mainboard MSI Z390 Gaming Pro Carbon
Graphics CardZotac 1080Ti
Memory G.Skill RipjawsX 3200CL14 2x8GB
Storage DriveHP EX920 NVME
Display Acer XB271HU
Power Supply Unit EVGA 750w G3
Casing Coolermaster H500P
soreloser
What's the budget
chrislzh
Hi. I would like to build a high end build. For gaming as well as light video editing.
Seek advice which CPU should I go for Intel or AMD. Don't mind to spend one time to get everything right.
Not going to overclock anything. Will use components as it is.
soreloser
Not sure what the prices looks like now. Just looking something to refresh current set-up (been long overdue). No need every part extreme or need to OC. Just to play game only.
If AAA games,
CPU: Ryzen 7 7700
GPU: 5070 from thetechyard $759
All the other parts are up to u. Might want to request an AM4/5 mounting bracket from Noctua before you buy everything .
NightRaven49
ur current setup is somewhere between recommended and minimum specs for bf6. i dont really see a point to upgrade, maybe u can just try playing the game on ur pc first when it launches then see if really need to overhaul. do also mention ur monitor resolution.
whats ur budget?
amd is generally better nowadays for gaming.
DriftKing
whats ur budget?
Cmi, tried 2042 it's barely playable for my liking.
Money not much issue, just mentally exhausted to reinstall OS and building up pc. Monitor 1440p. Eyeing to move up to OLED in future
Bardiel
Looks great man. How far the prices go doing own picking vs just off the shelf like invader? Any downside going mansa/invader/aftershock?
they sell u what they wanna sell. diy is u pick what u want.
after sales see ur luck. most of them 1st year so call onsite. after 1st year then is upto you. u can check out their reviews but i can say avoid kena shock.
