radzkal
Anyone good casing to intro? budget around 100-150
very broad question. you need to figure out what kind of aesthetic u want. got different categories. got small-form factor, got mid-form factor, got huge towers. personally i like small footprint so i settled on meshlicious (considered sff) but internals are packed tight like sardines. thinking of changing to a matx case like tecware fusion 2 which costs <$100.
soreloser
I'll always recommend the mid tower montech air 903 max, costs around 90-100$ and has 4x case fans included with good cable management. No additional fans needed unless you want to add some.
NightRaven49
Hey guys, looking into building a rig and wondering if these will work or am I better off getting a prebuilt. Most intensive usage is probably going to be maya and after effects. Prices are chapalang from various sites including amazon so might be different already.
CPU - Ryzen 7 7800X3D ($565)
Cooler - Thermalright Peerless Assassin 120 ($43)
Mobo - Gigabyte B650 AORUS ELITE AX ($284)
RAM - Lexar Ares 32GB ($134)
SSD - Crucial P3 1TB ($55)
GPU - PNY VERTO GeForce RTX 4060 Ti 16GB ($688)
Case - Montech Air 903 Max ($97)
PSU - Corsair RM1000x 1000W 80+ ($184)
Gonna be doing both since is my home pc, I don't play much AAA though. Is X3D worse for work stuff? My friend who also does 3D has another AMD CPU (5 something) and it supposedly works well for him so I wanted to try out.
like deepblue mentioned, if ur not gaming, its not worth spending the premium on an x3d cpu, especially since the 78x3d is selling over its msrp. the x3d chips have reduced clockspeeds to reduce thermal loads on the 3d vcache, adversely impacting performance in both maya and after effects which are clock dependent. intel traditionally does better than amd in those apps, and 13th/14th gen might be worth considering since the stability fixes have been rolled out, though amd can still be quite competitive.
other things i would change include the gpu and psu. the gpu u can afford to go for the 8gb variant since u are not gaming and wont likely run out of it, $700 is chopping carrot head for what ur getting. the overall system is also not very power hungry (1000w psu would be a very wasted purchase), and u can opt for the seasonic core gm550 for $80 from performance pc with 7y local warranty.
FOr PSU i looking to purchase locally. Looking at MSI mag a750gl or corsair rm750e or adata core reactor 750w. those are okay right?
yes. i would pick the core reactor, rm750e and a750gl in that order, though the core reactor may be difficult to find at a good price.
looking into i7 12700 too, is KF ok or do I want the igpu?
might be worth getting for quicksync for avc and hevc workloads.
Bro how u get the cpu so cheap, i search in amazon and the cheapest i found is $445 and RYZEN 5 7600 is $285.
neither of these are worth it. getting a 7500f or 7600 used will be much cheaper with no real drawbacks.
first post has a few at the bottom.
iceblendedchoc
If i looking for good airflow and quiet case?
That one depend on your fan choice and fan curve. The noise come with fan control. Some fans are quiet some are like helicopter even when on the same watt.
a lot of consideration for good airflow. Do you game in air con room? If yes a sff case will work even. Do you want to use sfx psu ?
Do you want to use smaller motherboard like itx? Do you want to use a long and wide gpu like a 4090 inside ? Or you are happy not running the most powerful gpu inside? Air cooling for cpu may have height limitation and aio can be limited as well. All depends on the configuration
the sweet spot is probably still matx motherboard and atx psu in current market for choices and costs in some three fans front intake matx casing , one rear out to create positive airflow. Of course now also have bottom intake side intake and top out options casing now
deepblue_82
after watching youtube on this.. this is really pretty good use usb c too
crazy 4 fans and alot of holes for cable management and also can manage the psu...
good stuff
masashi
So initially I pre-ordered the beelink ser8, however some bros suggested I could get something better around the $900 range and chose this with the 10.10 discounts. Apparently the PSU being installed is totally trash. And it seems I am unable to cancel it anymore. So are there any good PSU for me to replace this one?:(
xiaosen
For ram, teamgroup or adata one better?
TeamGroup DELTA RGB DDR5 6000Mhz 32GB
ADATA XPG LANCER BLADE RGB 32GB
NightRaven49
see if performance pc at sls still offers the seasonic core gm550 for $80.
ram is look less at brand and more at the timings on offer. what are the cl numbers of those kits? generally u want the cl numbers to be as low as possible for the lowest latency.
masashi
Thanks I'll check it out next week!
Looks like it's sold out. Fuwell has it apparently
xiaosen
Both cl30
deepblue_82
the name alone is very foreboding.......
herzog21
Hi everyone. My existing rig is more than 10 yrs ago. Thinking of building a new rig but have been out of the pc scene for so long liao. Need some help here pls.
Considerations:
1) Was asked by my ISP to consider upgrading to 10Gbps plan at the same price
2) To link 3-4 monitors for work purposes
3) Rig must be quite fast and smooth
4) Medium gaming
5) Torrenting
All from Dynacore. I may shop around for better deals
ASUS PROART X870E-CREATOR WIFI + AMD Ryzen 9 9700 - $1300
TEAM T-FORCE DELTA RGB DDR5 6000MHz CL30 AMD 32GB - $175
Msi RTX4060 Ventus 2X 8GB Black OC GDDR6 - $458
Thermalright Phantom spirit 120 se - $65
Samsung 980 Pro 7000MB/s Gen4 Nvme M.2 500GB(5yrs) - $105
Msi MAG A750GL-750W ATX3.0 Pcie5 80+ Gold - $127
Fractal Design POP Air Rgb Black TG Tint Casing - $135
Windows 11 Home 64-Bit Eng OEM - $162
I have a few questions/doubts about what I chose.
1) Are the fan and psu sufficient?
2) What's the difference between Win 11 Home and Pro?
Any advice for this are much appreciated
deepblue_82
Considerations:
4) Medium gaming
5) Torrenting
copy from the front posts
Case: Montech Air 903 Max $100
Extra fans: 6x Thermalright PWM TL-C12C-S ARGB $32
GPU: Powercolour 7800xt $650 Thetechyard
Wd xn850x at least 1tb or 2tb
please not Msi RTX4060 Ventus 2X 8GB Black OC GDDR6 - $458 if u intent to use the new rig for the next 10 years, pro vs home is just bitlocker drive.... and there is others ways to get it and not paying 162, would only cost 20 at most
NightRaven49
dont see it in their price list :look: if it costs more than $90, ur probably better off getting the silverstone va-650g from bizgram.
Both cl30
then get whichever is cheaper. if both same price, then it doesnt really matter, just get whichever u like the look of more.
yes.
feature set lor, can go google. if ur already using home on ur current rig and its enough for u, then probably no point going pro.
however, seeing the build as u mentioned:
this costs 2.3k before windows key. getting only a 9700x + 4060 is quite poor value for money given u can build a 7600 + 4070tiS for roughly the same amount, which should be quite similar in general use but much much faster (+110%) for gaming. the latest gen of amd cpu (ryzen 9000) + mobo (x870/e) offer very incremental upgrades over the previous gen. for cpu, just get 7000 series, it will get u 95% of the performance at a significantly lower price point. for mobo, x870e only makes sense if u have a need for usb4, multiple high speed nvmes and expansion cards, otherwise b650 is enough for most users. paying $1300 (which is enough to buy very high end gpus) on a cpu + mb combo is asking to chop carrot head, u will get a very similar experience with a much cheaper combo, for eg a 7700 + tuf b650m-e @ $510. even if u need a 10g nic, just get it as an expansion card, it will definitely not cost the $800 (!) difference. i also probably wont settle on a 500gb nvme, especially if u torrent many things at once; the top up for double the storage to 1tb is $40, can be halved if willing to consider the crucial t500 or wd black sn850x.
