kaixax555
- Nov 6, 2007
1. This B650E-F Strix is ok, but moving to an Asrock B650E PG Riptide would probably allow you to get a 7900 or even a 7800X3D, which would overall be a significant boost for gaming. The B650E PG Riptide has the same VRM as the B650 Livemixer which buildzoid reviewed and is more than capable of powering a 7950X (which I did). Getting a 7900 would give you 4 more cores while getting a 7800X3D will give you more gaming performance.I am trying to get a build up to replace my old Haswell PC but very lazy build myself.
Mostly gaming, video editing and encoding.
Are all these parts compatible with each other?
Few questions:
Looking at ASUS or Gigabyte Mobos, any additional recommendations? Guess most of them have min 4 SATA ports?
Is it worth to go up to 7700X or is the normal version ok
5600MHz vs 6000MHz - doesnt seem too worth to upgrade?
PSU able to withstand all the way to 7900XT?
Preferably will go to 1 shop to settle everything
MB & CPU ASUS ROG STRIX B650E-F GAMING WIFI + 7700X RAM KINGSTON FURY BEAST RGB 5600MHz CL36 AMD EXPO (2x16GB) GPU RX480 (Reuse, probably upgrade to 6750XT) SSD Crucial MX500 2TB PSU Corsair RM850e Case Lian Li PC O11 Evo Black AIO Artic Freezer II 360
Thanks in advance
The RAM is ok, it would probably be Hynix die, you could manually up the frequency to 6000MHz and tighten timings pretty well.
I have the exact PSU, I use it with the 7950X + 7900XTX, it should be fine though I think you can also look at the Asus Strix 850W PSU for a similar price.
Parts are compatible though you can look at a M.2 SSD if possible since you have that option.
