DNS-323 Network Storage
win_man
Where is the link to teach you how to rename Volume_1? I need to rename it to \images
Bieffe
may I know the proper procedures to update firmware of the DNS?
Backup ur data.
DL the firmware from Dlink webby.
Login to admin page of 323.
Click the last tab (if i recall correctly)
then there is a update firmware.....click and browse to the DL file and click update on the 323 admin pag and u will be done.
Also for updates do use LAN instead of wifi....not say cannot be not recommended lah.
NICKseven
Backup ur data.
thanks alot
hellhole
hey guys... i have this problem that my 323 is not able to be on always...
i have a desktop and the 323 all connected through wire with my dlink router. i am able to see the folder "Volume_1", but sometimes when i access the folder inside (through shortcut).. it will hang and not able to access...
i try to off and on the 323, but still the same...
any one got any suggestion?
Bieffe
I think your DNS-323 and desktop are on different workgroup.
Bieffe
I have some torrents that doesn't start in Clutch but if i use bitcomet the same torrent works....any idea why?
nsguru
any idea where to get at cheapest price beside second hand? All selling at $22x++ without hdd inside.
chriscel
I'm using firmware 1.06... is it advisable to update to 1.07 ? Thanks in advance....
revogsx
no need to update to 1.07 if you are not using the affected hitachi drive
i am on beta 1.08 and seems stable for the way I use it (only ftp and network access) plus funplug
psyko
I just bought a DNS-323.
Installed harddisk, tried to access the web UI to config, blank screen.
Removed harddisk, tried to access again, blank screen.
I tried pinging the device, it responds and I can see the LAN icon blink on the device.
The IP is correct.
Anyone can help?
Tried resetting already and still the same.
cloud77
hi everyone, i just reformatted my NAS HDD recently and also re-install the BT application via search utility. However, i am unable to delete those files in my complete torrent folder. Have tried to change permission of the folder etc and i have also grant access as read/write for the account but still same. Can anyone advise pls ? thanks
aaron_neo
Hi everyone.. i just bought the 323.. have some problems with the ftp server.
Currently using mio 2wire router to port forward 21 for the 323 already.. but still can't access from my wan ip.
Another problem is using ps3 to use 323 as a upnp but i got a "dlna protocol error 2104".
Can anyone advice on whats wrong? thanks in advance..
Hi, I am experiencing similar problems. I can access the drive locally but not over the wan ip address. Can anyone help? Thanks in advance!!!
cyberian
Do you have an account with DynDns? If you have an account with DynDns, turn on your DDNS setting on the router, it should work.
Bieffe
Just removed the old drive and pop a new drive into the vacant slot. Now formatting. Fingers crossed.
