Dust Blower for Cleaning PC
Swiftbladez
Just get the stanley blower. Used it twice for 2 different PCs already. Works perfectly fine and cheap too.
twlee88
its indeed very cheap compare to others 100++..is the wind strong enough to blow all the dust even in small tight place?
if its good, im gonna hoot this istead of metrovac:s12:
kandinsky
The Stanley one looks more versatile, in the sense that it also has vacuum function if you want that option. Blower function blows the dust all over the place anyway?
micheloving
I bought the 50+ stanley blower , its quite solid .
These blowers are definitely much stronger than those small expensive computer blowers .
They are not really meant for small tight places but max power will get the job done regardless .
The problem is they are bulky and very noisy .
U'll need an extension cable too .
Swiftbladez
Surface dust still needs to be wiped. Will be the same for metrovac too. Otherwise more or less all other dust will be blown away. And yes blow all over the place.
jtjt00
You can't expect the blower to clean dust like a damp cloth swip.
CCCustom
Anyone can advise what is the best way to buy this locally? Lazada or Qoo10? I don't have a Frank card though, and never bought anything from either Lazada or Qoo10 before :(
koroshiya8
i've been using metro datavac for > 1 year.. very useful for blowing off PC cases etc.. honestly it's very expensive considering the frequency of use but i got it at a cheap price last time from amazon..
if u guys want to borrow can pm me but self collect at 10kkj only.
PaLmEr-
You can purchase it either from the Singapore distributor or it's resellers. Chamoxa is one of the resellers
avsquare
How much you paid?
