Dust Blower for Cleaning PC
koroshiya8
How much you paid?
my first batch actually bought from B&H....
can only buy 3 to skip GST... tat was 2 years ago.. now price apparently has gone up.
The more epic one is below;
Amazon made a huge mistake, sending a 110v one which cannot be used.. think their website put wrongly the voltage.
avsquare
wah really not cheap sia :s22:
jedi5diah
i have tried dust blower, if your system already used and not clean for sometime, its not very useful as the some dust is "stucked" how u blow also won't come off...
need to regular Blows to do the Job lol...
koicafex
they won't come off even if u use other blower or compressed air also what :s22:
the moisture cause them to stick onto the surface, need to use finger and cloth to rub them off
jedi5diah
when i first bought it i tot its gonna do miracles lol...
as mentioned, so need to do regular blows lol for maximum effect...
PaLmEr-
Get a good 1 inch paint brush and use it in conjunction with the DataVac. Works wonders!:D
Swordsman
its indeed very cheap compare to others 100++..is the wind strong enough to blow all the dust even in small tight place?
if its good, im gonna hoot this istead of metrovac:s12:
just blow only..
or get a vacuum cleaner to suck it away ?
super365
I just bought the stanley blower, how to use the blower in Singapore?
The stanley blower 600w stel680 2 pin plug, has the text (text is seen between the 2 pins) that wrote: 250V 16A
That 2 pin plug is listed under "Non-Standard or Non-Approved Plugs in Singapore." row 4, at http://www.dmse.nus.edu.sg/safety/DMSE_Safety_Website/Electrical.htm
"Electrical supply in Singapore is 230V, 50Hz A.C. Most 3-pin electrical socket outlets here have a maximum current limit of 13 amperes (A). Ensure that electrical equipment can be used under these conditions before plugging them into the electrical outlets."
"Travel and universal adapters should NOT be used to accomodate the non-approved/non-standard electrical plugs above especially if they bypass the grounding/earth pin/strip of the original electrical plug and if they do not carry a Safety Approved Mark. Non-approved adaptors carry the risk of insecure/poor electrical contact. More importantly, they do not adjust frequency, voltage, grounding or overcurrent protection to allow safe use of "foreign" equipment with the local wall electrical supply/socket."
source http://www.dmse.nus.edu.sg/safety/DMSE_Safety_Website/Electrical.htm
Singapore is 230V, 13A
How to use the blower in Singapore?
Thanks
commach
Thanks
The plug rated at 250V 16A, not the blower required 16A to operate.
600w is not equate to 16A at 230v Singapore power.
jtjt00
Super365, rating on cable is what the cable can carry and in your case is 250V, 16A. Your blower has its own rating too, and is likely to be lower than that of the cable.
My Metro Datavac Duster also comes with 2-pin round 250v/16A plug, but the duster rating is only 230V/2.3A.
So do not confuse cable rating with appliance rating. In short, cable current rating should be higher than that of the appliance connected to.
super365
Is it just use any adapter plug that can insert the 2 pin into it, then plug the adapter plug to the wall socket plug can work already?
Any recommendation what adapter to use?
Use this can?
jtjt00
As shown in my image, I use $1.50 adapter to connect the 2-pin plug.
commach
Use this can?
Sure, it will works, no issue at all.
The blower required only 600w, only about 1/5 of our 230v 13A (3000w) AC power.
super365
Thanks jtjt00, commach.
I looked at the manual, box, site and only found the box says 220-240V 50/60Hz 600W. No mention of how many A anywhere. Can estimate how many A?
commach
Approximately 2.6ampere, a long way before you hit the 13ampere output. :)
jtjt00
Power (W) = V (Voltage) x I (Current)
600 = 230 x I
so I is about 2.61A.
super365
220-240V does it mean that it needs any voltage between 220-240V to work? That means it can work in any of the countries that has the voltage from 220 to 240V.
