Dust Blower for Cleaning PC
super365
Buy Stanley Stel680 blower. I am using it, it is good enough. Save you $100+. 1 year only use once or twice, no need expensive pretty datavac not worth it.
micheloving
50 bucks (cheaper if ard 30 bucks if u have qpts and coupons in qoo10) enough to last you for years. datavac doesn't really work for spore voltage anyways and is much more pricey .
Leafblower is the best really . Some strong vaccum cleaners can blow too.
Dun need to spend a bomb just to 'blow' computers lol once a year.
harky
size too big sia...
ppl say like machine gun?
kiama
erbasicco
Thanks bro for that suggestion, didn't know about this blower. $50 ain't too bad not to mention more powerful than datavac
Gymrat76
I just bought the DataVac yesterday (or rather, I placed an order). Think it's pretty expensive and it's something I've been thinking about for a while. Every time I decide not to buy then I regret when it comes time to clean my casing =p
So just decided to bite the bullet and buy. Didn't go for leaf blower because of the size and my wife would kill me. Maybe if I lived in a landed property and ALSO had leaves to blow I would consider lol
PaLmEr-
there are 220 volt versions specifically made for Asia available locally.
idjekyll
I was referring to the Metro Datavac ED500. Apologies if i did not make the message clear. :s13:
no la actually i was asking about it in general. pretty awesome and quick with to remove the dust build up but im wary of any damage it may cause.
yosemi
where u guys use the blower?
i live in hdb sia..i blow in my room is like selfpwn
PaLmEr-
No issues at all so far for past few years for the datavac.
