e-Remote Broadlink RM-Pro
Aditshar
Here is my setup :
- TC2 switches (for all my lights)
- 433mhz RF powerpoint switches (for my standing fan and water heater)
- 01 x broadlink rm pro (main unit)
- 01 x broadlink rm mini (control aircon)
I'm using e-control app to manage all of them now. My question is, is there anyway that i can link the app to google assistant so i can use voice command?
Rebirth
Can anyone share if they tried linking this light switch brand -BIGIN-
With Broadlink RM Pro?
Keen to buy this for my New place, kindly advise Bros.
Thank you
xenocide
Here is my setup :
there is a thread in EDMW for smart home discussing this
Problem with RM Pro is its not direct PnP
You need a bridge device for it to work.
xenocide
Thank you
just checked for you and you're in luck
BIGIN is one of the brands that RM Pro can support
Here is the list:
BIGIN
Broadlink
初冠
CHUANGCHENG
CHUANGSHENG
FUNRY
QITA
SANKOU
Yoogee
LoneTraveller
Hi all,
Can I check with the experts here as to whether the rf switches shows their on off states on the broadlink app?asking as I am looking for Something to ensure that I off all my aircon and lights when I leave the flat. Tks.
newlife80
Hi Aditshar,
For the below switches do u connect neutral wire to the TC2 switches?
Here is my setup :
xenocide
Hi all,
does not show status
alvismah
Here is my setup :
hi can show pic ur - 433mhz RF powerpoint switches (for my standing fan and water heater)? tia!
Rebirth
Here is the list:
BIGIN
Broadlink
初冠
CHUANGCHENG
CHUANGSHENG
FUNRY
QITA
SANKOU
Yoogee
Manythanks for you help bro!!!
Will provide an update once this is done
azt18a
Here is my setup :
Do monitor your PowerPoint switch for your water heater as some water heater uses high current and may burnt your powerpoint switch.
Do check your powerpoint switch on the max current it can take, like 13A. If less than that, have to double check your water heater current usage. If written only watts, you can divide by 230v, can get the current that it normally used.
Then can roughly know how good is the PowerPoint switch. You can also feel the heat from the switch, if warm or even hot to touch, you have to be careful.
MaoZeDuo
Hi is anyone using Livolo wall switches? Is it able to provide status feedback?
dwan
Here is my setup :
Possible with/without bridge.
Hi Aditshar,
Neutral wire not required. Using single Live wire.
I bought my switches from aliexpress (
https://www.aliexpress.com/item/32810065674/32810065674.html) & RM Pro from lazada.
Problem now is how do i cover my corridor 1 gang 2 way switch to using those smart wall switch? Anybody got solutions or links to buy smart 2 way wall switch?
Try Livolo 双控触摸
rza29
Bro I bought US switches and it can work. I
Dont think any issue
With EU or UK one bcos the size is correct.
Hi, check with u all....
for the RF wall switches(no neutral) i saw at the back of the switch stated,
1. EU version they wrote 7w-200w/gang (100w/gang if using with LED lights)
2. UK version wrote 7w-200w/gang, total 800w.
is there realli any differences ?? in SG context understand we can actualli use both the EU or UK version as voltage, size of switch is similar.
So can I safely say I can purchase a EU version to use in SG ?? is there anything i need to take note ??
Aditshar
No worries. I'm using hager esc225 contractor for my storage heater. Max 25A. It act as a relay switch. High current to Low current back to High current.
Aditshar
I donno how to post pictures. But they look like those timer plugs with just one button on it. It come in pack of 5 with 1 remote control.
Aditshar
There is no neutral wire on wall light switches for HDB hse. The neutral wire goes directly to ur light. Unless ur home wiring has special arrangement(that will be a different story). You will see all brown wires when u open ur existing light socket. You need to determine which one is 'Live' and 'Load' wire only to fix on the touch panels
Hi Aditshar,
Aditshar
I made 2 way to become 1 way switches. Since now i can control my switches with my phone and Android box, i dont see the need for 2 way switches anymore. Its the matter of getting use to it
