e-Remote Broadlink RM-Pro
BenBen010103
No, I order from one of the Local Supplier found in Carousell and the Touch Switch is similar to the Livolo Touch Switch with Round Touch Button but the housing inside the switch is made of Metal instead of Plastic.
I only get 1 RM Pro at the moment to link up all the Smart Switches first then slowly add more to connect more devices together so depending on the coverage of RM Pro.
No problem installing the Touch Switches though there is some difficulty installing the 1 Gang 2 Way Remote switch as the wiring is a bit different from traditional 2 Way Switch.
Bro, can share how you did the connections for the 1 gang 2 way remote switch wiring? or even for the 2 gang as well as 3 gang, thanks.
BenBen010103
Are the Broadlink TC2 switches 2-way? If no, how to make it a 2-way?
Saw Bro Carlover76 mentioned that he had no problem installing the Touch Switches though some difficulties installing the 1gang 2 way remote switch. I wonder is he referring to the Broadlink TC2?
spyderbil316
Hi, any one can recommend me the light switch cover?
I'm looking to set up my smart home using Amazon Echo Dot and broadlink remote.
Wondering how to link the light switches up.
Can any one recommend the type of light switch cover as well?
Are they standard size also?
daniel_83
Any idea how to connect Google Home to Broadlink RM Pro?
I want to ask Google to turn on my ceiling fan
rsrsrs
1. I am planning to use broad link to control my Aircons, but I have two aircon units in the living room in close proximity. is there anyway to isolate the control of the aircon individually.
2. Is there any problems integrating two or more broadlink rm pros in the app.
3. Did u use the broadlink switches (tc2)? Is it compatible with the other brand switches?
Hi Bro,
Did you manage to get a solution to the multiple aircons in a single room?
I know the RM can learn IR commands but, my single aircon remote can control all aircons. In this case, when the RM blast the IR command to power on, does it mean 2 aircons will power up at the same time?
terumo
Most likely both will on at the same time.
Hi Bro,
kitz79
Hi. May I ask if we can set the remote control on 2 mobile devices to control 1 Broadlink device?
ray0006
yes..both ios n android can control 1 broadlink device. But for sharing of the data i think need to create an account in the app. Cannot remember if the wifi sharing function works or not.
kennyboy
Hi Bro,
Can get multiple RM devices to target each aircon separately. Not that expensive.
sgtouchpanel
Just create another account, there is a function call sharing. Both phone must be in the same network, copy paste all the configuration over via sharing function
kennyboy
Or just use 1 account, cloud backup works just fine.
kensou
i cant seems to configure my broadlink to e-control app or ihc app..
I tried both 2.4ghz and 5ghz method don't work. i tried both ios and android. I tried WPA password protect and Open Network. All doesnt seems to work. Any1 got any solution? I spent few hours resetting and resetting still cannot.
Even AP Mode also cannot. :s11::s11::s11:
ray0006
only the 2.4ghz network will work...
Did you try to hard reset your rm pro, need to press the reset switch for some seconds...
kensou
I hope its not because i buy from taobao thats why it wont work >.>
ray0006
i dont think so...Did you use the function "Add Device" from the e-Control app?
Maybe try to join the same 2.4ghz network from your phone before you try..
kensou
its not the 2.4ghz problem. cause i know i am always on 2.4ghz. Anyways I managed to get it to work once on e-Control, my android Samsung phone just doesn't want to configure and add it to list. Its like a random chance thing, sometimes it work sometimes it dont.
When on RM Plugin, I managed to get it to show IP Address on Alexa bridge on my device just ONCE. After that it keep saying unable to manage device..
