e-Remote Broadlink RM-Pro
RyanJ
Bought a couple of new RM4c mini to try. Realized it doesn work with the ( old ) Broadlink app.
FB msg Broadlink and was informed to use the ( new ) Broadlink app which will have data from IHC ported over as long as same login credentials.
In the longer run, new Broadlink app will supercede both the old Broadlink and IHC.
fyourlife
Is there anyway for Broadlink switch to use a timer mechanism ?
e.g. I only want to turn on the water heater for 30 mins via the app. Would it be possible with the existing apps / IHC ?
spiky0180
Ok I managed to get it setup. Not sure what is wrong also. I shifted the broadlink across my desk nearer to the ceiling fan, maybe about 30 cm horizontal distance and the kdk fan can detect.
Not sure if the KDK IR sensor is more sensitive. My TV not affected by the distance.
Will have to monitor.
Yes, my KDK fan is set up as a lamp on my IHC app. I’m able to control it via my GHM and on the app itself.
Elon Jobs
Yes got to play around abit, my RM Pro controls my fan, aircon, TV, soundbar and Mi Box in my living room. It took me while to find the optimal position for all five IR devices.
Elon Jobs
Broadlink having year end sale again, I was thinking whether I should get this temperature/humidity sensor HTS2 but I got to buy the new Mini 4 to replace my existing Mini 3 in order for it to work. It’s not backward compatible.
Any experts here use this sensor before? Any feedback? All in about $36 after discount. Is it worth the upgrade? My Mini 3 still going strong after almost two years.
http://sg.carousell.com/p/265585233
cueball1981
Guru. Need your advice. Being using TC2 for years. Recently install a few TC2 at my mom place. The TC2 seem to be resetting itself. Suspect is glass panel touch. As the moment I cover it will reset and hazard flicker.. and advice no to fix this.
Nainai
Hi guy anyone got problem with the TC2-1 gang switch?
I can’t add it in IHC, keep giving me “index HTML not found”
zulthezookeeper
By any chance you wired up with the circuit breaker on?
viix
Anyone using ecoairx fan able to connect to RM pro?
Using the PO eco one.. same driver as the ecoairx.. can connect to RM Pro but off function doesn't seem to be recognise I think.. Didn't really try as Im using IFTTT linked to homey to turn off..
leo_wen_sg
Is there anyway to transfer rf codes from e-control to ihc? My ceiling fan works on e-control but not on ihc.
Specialfeelings
Hi guys need some advice. My TC2 was working fine yesterday using Google home, but now suddenly it doesn’t work anymore using voice command or the Google home app, and in the Google home app it states as offline. I try turning them on and off using the ihc app and they are working fine. Any idea how to resolve this issue?
Elon Jobs
My scenes weren’t working with Google routines last night. But I could still voice control my lamps, but when it comes to routines involving scenes, my GHM replies “I-H-C isn’t connected right now”, then followed by the custom phrase I’ve saved.
This morning, everything back to normal. For you guys, I can only suggest de-linking IHC under the Google Home app, force close the app, then relink again and see if it helps.
Specialfeelings
Just tried what you suggested. Didn’t work :(
Elon Jobs
Okay, last resort you can try log out and delete both apps and reinstall see it helps. Lastly, if you’re iOS, try re-link on an Andriod device; if you’re using Andriod device, try re-linking using an iPhone or iPad.
Hope your problem is only temporary.
kelvinang
I'm having the same problem too, everything working well until yesterday. Not sure if it's because of firmware update.
Now some of my TC-1/TC-2 lights can't be paired to IHC app at all.
Tried below but to no avail
1) Unlink and link IHC
2) Restart circuit breaker
3) Delete devices and add again - but I couldn't pair for some (for those that were able to be paired was not accesible via Google Home - can see but can't turn on/off, only IHC can)
