WussRedXLi
- Jun 15, 2001
300ml water tank.
It takes 53 seconds to empty a full water tank. Not too bad.
Panasonic AA is 40 seconds with a fully recharged set, on average would be around 50 seconds. But note the Panasonic has a 160ml reservoir.
The pressure PSI of the h2oflosser is power, would not be lower than the Panasonic or Waterpik AAs. Coupled with the higher flowrate, absolutely no complaints with regards to the power.
So the issue is that coz it is so power, newbies with lousy gums health (typical) would find it difficult to use, coz for sure the first week would be a bloody sink and sore gums every single time this is used.
As you can see in the latter part of the video, the power dialed down is not very obvious with the water stream hitting the shampoo bottle. Just a little, like 30% down.
The mechanical switch seems good, very clicky, i think will be able to survive 2 years. The NiMH pack is 1500mAh 4.8V, anyway it's a 4-cell pack.
With my experience with chinese NiMH, this should last 1 year before you can find the performance degrading, maybe 2 years tops. Of coz these are not Eneloops, which'd easily let you use 3-4 years, even more.
I think 1-2 years of usage should not be of any issue. If heng, can use 2-3 years mark, more than enough for this cost.
The battery pack is not moddable or serviceable due to the small size. Past few posts i have mentioned that users modded theirs with 18650s (aircon cleaning), i believe they were modding another h2oflosser (countertop versions).
Even if it's SGD 30 shipped, it's still ok.
