Exchange Rate - Part 2
kkboy1
Youtrip withdrawal only $5 fee at any atm? Is there any other atm charges?
naxchua
Now I m on my way to raffles place to settle my outpro stuff then go arcade and change money...
naxchua
Today's rate at arcade for TWD is about 21.
Can share the rate when u are done? Waterway Point money changer rate only 21-x
I only managed to change TWD$21.97... Most of the money changer either is 21.08 to 21.93 or no stock... Not sure why... I only checked 2nd level...
kkboy1
Hi. Anyone have the exact location of the ATM that can withdraw greater than NTD 20k in one single withdrawal using youtrip? The exchange rate is better using this method and if I can withdraw like $2000+ at one go, I can save on the S$5 fee per withdrawal. I am looking at ATM nearby Taipei Main station or Airport. If it is a short metro ride with Taipei Main Station will also be OK. I see from the chats above, I should be looking for Cathay Bank ATM, correct?
If feasible, this is first time trying my hands on ATM withdrawal in a foreign country.
:p I see from youtrip website, need to select "saving account", and select "local currency". Anything else to take note? Revolut is not an option as the exchange rate is not as good as youtrip?
I am intending to do this too. Not sure airport got atm to withdraw?
Seifer28
sure have ATM lah.... which airport got no ATM?
the only issue is whether you only want to withdraw 20k or you want to withdraw more
otherwise, just bring abit of cash and exchange at the money changer at the luggage area before you exit the immigrations
Seifer28
bro, then why even change when its so low?
calkel20
It happened way back on the 15-16/11 week. Like no input ntd one.
calkel20
i last time alw walk in to DBS bank TW change money because they usually have the best rates vs other banks in TW even after accounting for their 1% txn fee :p
That was the 12-19 times if i recall well.
Now need to know which one can withdraw more than 20K if not, doesnt seems worthy to withdraw using yourrip.
calkel20
erm... will the rates be good at taoyuan airport??
No.
exchange at airport is lower than Singapore’s arcade and also incur a small 30ntd/transaction.
Any change now, no idea as i rarely change at taoyuan airport anymore.
ApeTruelove
No.
Yes now Taoyuan airport rate lower than Singapore already..
Seifer28
BY RIGHT,
Youtrip is wu hua one.... coz i used UOB AMEX Absolute to topup grabpay then topup youtrip.... this gets me 1.7% rebate right away
BUT they just nerf-ed the function.... so right away from wu hua become maybe bo hua
If anyone want to check youtrip exchange rate real time can refer to below link:
https://www.mastercard.us/en-us/personal/get-support/convert-currency.htmlOn top put ur TWD and amount
Below put ur SGD
Bank Fee put 0%
Joelleyuan
very bad rate now...
I'm flying 23rd Dec,
you guys think the rate will go up again or may be even worse??
Seifer28
Single withdrawal limit
Shanghai bank: 40k
Fubon bank: 150k
Rest of the banks all 20k
Im not sure how accurate the above data is.... someone can go try and let us know
