first timer getting palit gtx 1060
AlvinDj
May I know the difference of Palit GTX 1060 3GB vs 6GB ?
Assuming they are the same version of the cheapest model?
ZrE0_Cha0s
all models are the same, at most 5-7%?? difference on avg of all games, but some games like no or minimal difference.
but still depends on which games u are playing, can try to Google for dome game benchmark.
AlvinDj
I meant the 3GB vs 6GB versions... I know the rest of the difference are to do with the cooling / OC etc only...
But what are the main differences for 3GB vs 6GB?
ZrE0_Cha0s
actually what I mean is the performance difference across all GTX 1060 (regardless of brands) 3GB and 6GB.
well these are differences (can be googled):
but with one fewer SM, reducing the core count by 10%. That drops the GTX 1060 from 1280 CUDA cores to 1152 CUDA cores (128 cores per SM), alongside 8 fewer TMUs. (source from gamernexus)
AlvinDj
The 3GB should be able to do 1440p @ 144hz ?
Currently on 1440p @ 60hz but might looking to upgrade 144hz in future..
ZrE0_Cha0s
sadly i dunno about that, and u might need to reduce your graphic setting just to allow u to play at that fps.
but there is one time i see the posting of a guy playing overwatch at epic graphic (not sure of the resolutions but probably 1080p) hovering around avg 120+ (max hit maybe 130?) but when shoot out becomes 100+
watzup_ken
The card is good for 1080p currently, and not so much suited for 1440p. The 6gb version I had worked well on my 1440p monitor, but newer games are more demanding.
xtwis7
144hz at 1440p is very unlikely. 1080p 144hz no problem.
AlvinDj
Sadly... all OOS :( Wonder if they gonna restock..
Delayed too long before checking out.. Damn suay..
AlvinLHQ
just hooted palit 1060 6GB SJS on lazada with singles day coupon for $340....delivery fee of $3 included...with shopback save another $6.75 :s12::s12::s12::s12:
should be compatible with my current set up right?
ZrE0_Cha0s
what's your current set up? any restrictions on the case? do u have any other pci/pcie connextend near the gpu?
AlvinLHQ
current setup in profile on right...not sure if it's visible.
don't have any other pci connected...i guess
as for case, have plenty of space, from what i see
Processor
Intel Core i3-4150 @ 3.50GHz + Cooler Master Hyper 212x CPU cooler
Mainboard
GA-B85M-D3H
Graphics Card
MSI Radeon R9 270 Twin Frozr Gaming OC 2GB
Memory
Kingston 12800/1600 8GB DDR3 CL11
Display
Dell S2340L
Storage
WD Caviar Blue 1TB / Crucial M500 120GB
Casing
Sharkoon T28 Blue Edition
PSU
Cooler Master G650M 650W 80+ Bronze Modular
OS
Windows 7 Home Premium 64Bit
ZrE0_Cha0s
Processor
Mainboard
GA-B85M-D3H
Graphics Card
Memory
Display
Dell S2340L
Storage
Casing
PSU
OS
Ah I see, there shouldn't be of any issues when u buy the card and replace your current system.
But please do remember to use DDU to remove your previous amd driver b4 installing the GTX 1060.
