Galaxy Note Accessories
tekster
finally i took the plunge man. got a zenus case plus 3M privacy screen protector for $95. bought in local shop as i couldn't wait anymore.
buy phone cannot use is v agonising. lol
tekster
update on NFC simulation fantasy....just tried ezlink at the back of phone with TPU (Something like what this korean anymode user did to the back cover)......
....can work leh....so i guess its not really phone interference but TPU material too thick (?)
no le. those auntie bag even thicker.
i ever tried to kiap between my 2nd and 3rd finger, card not touch the reader. can still read le. but somehow with note, it just doesn't work. i'm sure there's some kinda interference.
xtootx
Anyway, some pics of my Nilkin TPU.
Package comes with a TPU case, 1 x SP, and 1 x screen cleaner that you can tie onto the TPU case.
Compared to my current S-Line TPU
Overall, the cut outs are decent. The speaker alignment is good, not blocking. For the camera cut out, the lower part of the camerea assembly can be seen,similar to the S-Line TPU, but does not block the lens at all.
One thing that stands out are the volume rocker and lock buttons. They are covered, but much softer than the S-Line TPU. In the end, it feels much more responsive than the other TPU case.
er.. anybody knows where to get this case? Be it retail or anyone on HWZ selling?
Kurama9
Just received momax icase pro...will try this for my last attempt at "NFC" simulation
Case is of good quality, good cut out for all except speaker kindda off by a bit, cup the phone nicely with thin lip helping to raise screen, not as easy/fast to take off and put on as ultra capsule for batt pit-stop. Volume rocker and power button are covered with minimum protrusion but still very responsive.
when use without back cover for batt pit-stop, cut-out at PC part leaves a marginal gap which will allow some dust in and the TPU material part at side seem to attract lint...perhaps lint are also more visible coz of black colour.
Still a very decent TPU+PC hybrid for any1 who dont intend to do batt pit-stop. Will keep this i guess :)
Add on: MicroUSB and Ear Jack cut out able to fit rearth plug-ins nicely
waiting for ur new field report!
lorettatay
go search for a user called soyabeanmilkdrink. i just ordered 1 from him yesterday while waiting from my sgp diary case to come from US.
arcanehacker
Not really.. the Ezlink card works with the MFit case with card slot..
VoodooEx
I am looking for Zenus case as well. Which model did you get? Can post a pic? Where did you buy it?
renfred89
Phone does not interfere with nfc technology because our phones operate at much higher radio frequency. Eg gsm 900mhz. Nfc uses 20+mhz.
The reason why you can't scan your cards is because of the material you use to hold the card. Regardless of thickness, material that is not compatible with electromagnetic induction will shield your card completely away from the weak electromagnetic radiation emitting from the scanner.
In order for it to work, you gonna leave a hole for the radiation to hit the card, or you could wave the card at the scanner at a higher speed to attempt to increase the voltage generated by the scanner..
Hope my reply helps..
Akai Ryu
ya will try later today....
where do you get this momomax cover too? :)
got mine from ebay for fast shipping, other sites have it too
Illustrates how good ultra capsule's TPU material is and at wrapping around the phone even when there's no back cover
Momax's does have gap due to nature of PC not being able to wrap....well will just see how it goes later today
imacbie
Akai Ryu, are u using ur bunker ring?
if yes, you stick to where? battery cover or cases??
just ordered one for myself, dunno to stick to TPU case or batt cover :(
Akai Ryu
CC and Transcribe Audio + Translate Caption to get some sense of this korean review
ANYMODE PC bumper
TRYIT Flip Case
Keep a look out for how he demo the kickstand
Akai Ryu
Yup its on my Ultra Capsule, can reapply but i have not try to do that yet :o
onion07
Hi, can you share where did you get the 3M privacy screen protector? Thanks.
Gadgetfreakloh
My Note Flip case review
Verus Classic K
This is a very nice case and good fit and cutting. However the top and bottom parts of the phone is exposed. Nice solid flip that will last long.
Next up
Sena slip in case
Gadgetfreakloh
Sena Slip in case
Good case that is very slim and good quality. The screen will auto clean itself when you insert and take out the phone due to the Microfiber cloth interior.
Next up
Tridea Flip case
Gadgetfreakloh
Tridea Flip case
Super solid case that is basically a bumper case with nature leather feeling material. Very good protection against bumps and feel very safe. Cutting is also way better than the Verus classic K. Overall a very well made case that will last very long.
Next up
Tryit flip case
