Galaxy Note Accessories
Jhyun
Anyway, some pics of my Nilkin TPU.
Package comes with a TPU case, 1 x SP, and 1 x screen cleaner that you can tie onto the TPU case.
Compared to my current S-Line TPU
Overall, the cut outs are decent. The speaker alignment is good, not blocking. For the camera cut out, the lower part of the camerea assembly can be seen,similar to the S-Line TPU, but does not block the lens at all.
One thing that stands out are the volume rocker and lock buttons. They are covered, but much softer than the S-Line TPU. In the end, it feels much more responsive than the other TPU case.
Akai Ryu
How you place order ? All Korean wording..................:(
can keep a look out for gm spree, else its kr text comparison from its option with the descriptive pics
edited: check if the kr seller ship internationally
stylux
Any1 knows if acetone possible to remove the SZLF logo on the aluminium bumper ?
bikachu
Just bought martin fields overlay from mobilescape. Screeb protector is fine no lines after using stylus. What i like is mobilescape's service. Excellent. The guy was talking to a fellow note user and pasting for me. When he told he to check after 5 minutes. It was flawless. Done precise and fast. Very good 'pasting' skills. Dint take out put back like most. Once and done. Very nice.
How much is the MF overlay at mobilescape?
Jeremy1
u did not include ur dock, Stylus and god knows what other SP ?! :s13::o
remember to tryit.....this and let us know how this metal/leather flip case is
btw which colour u chose???
Chose black, no cover version. Don't really need it.
Thanks, I found the local English link already............
MP3/Mobile/eBook - [Galaxy Note case] Pawel Ruth Diary Type or Pocket ...
Already place an order on the Brown one with no cover.
Ok, who wanted to buy my black mercury jelly case. New one still not received from gm yet.........................:D
Letting go at $8................................;)
Jeremy1
time to change to glass sp liao
Heard glass SP may have sensitivity problem?
Anyway, I bought a Nilkin TPU, and it came with yet another SP, so can change again =:p
is this good? seems like this protect the whole phone including the side and bottom.
MP3/Mobile/eBook - SKINPLAYER Samsung Galaxy Note Screen and Body Prot...
Irregardless of whatever SP, I don't think finger print can be preventable.............................................:D
So just get a normal good one will do.............;)
otaku7
Contacted the Korean company doing the belt case.
I was asking them about the galaxy tab 7bplus and p1000.... Although no such model... But there's hope for note. See reply below:
" The above model Write down the quantity ordered Are delaying production.
The current model ipad, ipad 2, iPhone4s, Galaxy S2, Galaxy Note is. Are you a distributor? If you have a large number of order quantities, can be produced.
Thank you.
----------------------------------------------------GRIPIN Co.,Ltd. CEO / Jung-Jin Yoon Mobile : +82 16 206 8055 Tel : +82 70 7613 8055 Fax : +82 31 893 8056 Add : #104,119,Sanggal-dong,Giheung-gu, Yongin-si,Gyeonggi-do,SEOUL 446-905 KOREA"
theory_87
theory_87
The BeachBuoy Waterproof Case
This is good for outdoor people
Key Features
100% Waterproof Case
Dimensions : 185 x 135 x 5 mm
Guaranteed waterproof to 5 metres/16 feet
Closure System : two click seals and a velcro strip
BSI approved (IP57/IP58)
Instructions on how to fit the case : Undo velcro, unroll tab then pull apart so the two click seals come apart. Place device inside then click both seals together and roll up tab and velcro back down.
Includes attachment for lanyard
Use your device whilst within the case – make calls, use touch screens and buttons
Protect your valuables from water, dust and sand
Suitable for small and normal sized devices (mobile phones, cameras etc.)
phpThumb.php
SAF D&G also go similar... I used to use it for my maps and notes outfield (including river cross). I still have it ;)
