GALAXY NOTE II ACCESSORIES
Akai Ryu
tornedo
thanks!
will consider the oleo one when I get my note.
I tend to have oily skin from time to time :(
Do you have a physical shop or something to help apply the SP or must diy?
I also looking for sgp (most likely crystal) with good seller skill to help to apply, i am very bad with applying sp...got oily and shaky hand :(
kianshing
Anyone has tried Nillkin product before? This one looks cool.. Any idea how's its thickness? Thanks.
(Source: Nillkin website)
anddrool
why not try Rock cases by Adix82. Its pretty much same design and maybe better quality!
I don't like Rock cover design. I perfer Nillkin cover texture. I brought Nillkin cover for S3 and it works well.
Pricing wise, I can't complain for $11 which includes screen protector. The screen protector does the job as well. Anyway, after a few months if there is scratches on the screen protector just replace with a new one. Thats why I don't get expensive screen protector which will get scratches as well.
As longer as the protector is clear, transparent and does not affect display, I will just use that. At the end of the day it is just a piece of plastic and most of the time, if there are some minor scratches after using for some time, people will still carry on to use it and lazy to change it.
Akai Ryu
for those who like the UAG on S3....go pester and whine at UAG for note2 version leh :o
Thank you for your interest in URBAN ARMOR GEAR products. This is a terrific suggestion. No plans currently; however, the landscape of our product road is a constantly evolving picture and these products may become an option for us in the future.
URBAN ARMOR GEAR
striker22
Thanks for the recommendation, I just bought one from ebay. Not sure how long it takes. The price point is cheap enough though so I dun have to think so hard compared to $40-50. The free screen protector included if something happen *touchwood* should happen to my set, also won't feel heart pain if send for replacement.
