Gaming desks
ondooy
Omnidesk 2018 version. First of all, you need to know, all motorised desk are not stable after a certain height. Once it reached a certain height it tends to wobble like a lot.
If you wall mount your monitor, then you dont see the wobble much, if you use a monitor arm for the omnidesk, you will find it with a slight move of your mouse, it will send a shake to your monitor. Its annoying. Even despite putting the monitor on the desk with a monitor stand, it wobbles badly.
Unlike the galant series, it is structurely rigid. With the A frame legs. The table doesnt wobble. Yes not 1 bit unless you deliberately shake it hard.
The table material for omnidesk is far from good also. If you do do write on the table, since it is matte black finishing. You can see drawing or writing marks if you use a bit of force.
Lastly they market the cut in the middle to be in a bend shape to be good for egronomics, it is far from practical. It reduces the depth of the table space. And if you do put things on your desk. This isnt good.
Last but not least. The cable tray management. Is basic to none. Far cry from secretlab magnus table. I really dont recommend the omnidesk. Expensive due to the motor only. Just get something best and sturdy from ikea.
If i shift my house in the near future. I will replace my work desk to be of something more sturdier than this omnidesk.
damn, i just purchased mine. 😞
ondooy
got my desk during the sale. so far I find it sturdy and stable, the finishing is nice and has a premium feel to it.
at 110 height it doesn't wobble. it's a bit tedious to set it up, the legs are heavy.
with the discounts and cashback, it's super worth it. :love:
Gaminator
I bought a clamp on type monitor mount for my desk, the monitor stand I'm using is too small and too low. This new monitor mount is higher and allows me to put my Oppo HA-1 DAC, even has enough space between top of my DAC and the monitor mount for cooling. Pretty easy to install and has freed up more space on my desk....
azarel
ooh mind sharing where you got the clock? thinking of getting the same for my desk.
tc4237
Sitoca desks as well. It just won't die. Maybe rust and bulge due to water ingress. But still damn stable.
Any idea how to buy more from them?
tremor
Don’t bother with what gaming motorized desk. U won’t use the function one. Buy sitoca, your grandchildren can use it too.
cochran
no more good sitoca desk liao lei.... their website nothing much.......... My sitoca is like 20-30years liao.
summersky1986
My sitoca is about 25 years liao.. now in my storeroom.. I wanted to change desk to suit my house reno... but sitoca just won't spoil.. next time pass to children or use as coffin knn
evildoer
looking for a computer desk.. moving soon,,... how come now every desk shown pc do not sit on table anymore ?
i thought place on carpet is not good and place under table will have a dust night mare.
Any recommendation ?
Gaminator
Upgraded my dinky desk to the 48" Omnidesk Pro 2020, feels like so much bigger than my old one, No space to use those clamp-on headphone mounts/stands, except one in front right, but have enough space on desk itself to put three headphone stands. Re-used the clamp-on monitor riser, now using a Ducky Shine 4 Fire 69 full size KB because I now have more desk space.
Gaminator
I'd gotten the cable management thingy from Omnidesk (I think it was free) and spent a short time organizing my cable, stuck an APC multi-plug under the desk (using 3M Commander two-sided tape) and reorganized the wires and cables...so, I went from this:
To this...pretty happy with the result.
