gaming pc or ps4
shadow84
Guys, just to clarify on my comment, i was refering to his budget, and not about fortran selling products without local warranty. Please take note.
I wasnt clear in my comments and i apologise.
mike911
i think i missed out something.
Do ask yourself, "What games do I want to play?". Remember, not all games will be released in PC or/and console (i.e. xbox, ps, wii, etc.)
igniz12000
If the question is: Should I get a PC to replace my console as a gaming device? Then the answer will almost definitely be a no.
Its not worth the cost if you are just looking for the PC to replace your games console. You should however get a PC if you're looking at it as more than a simple gaming hardware ie. as a pure entertainment hub and more.
For me the answer is get a PC but I do my gaming, video capture/editing, game modding and movie and TV viewing on my PC and so its worth is way beyond any simple console to me. That might not be the case for you. You should consider the overall cost of both devices and see which is more worth it in terms of price and the usage you hope to get out of it.
One thing the PC has over the PS4 in terms of gaming is the cost of games. My cousin recently pre-ordered FIFA 14 for $80; on Origin the cost is almost half that amount. Not to mention Steam, Steam trading sites, GMG, Nuuvem, GOG all have prices way below the average cost of most console games and their prices drop very quickly. On top of that they also have regular sales events making the game prices even more cheaper.
If you want to compare PC and PS4 in terms of just gaming, I would say the PC has a much bigger initial cost of entry but the long terms benefits will soon overtake the PS 4 and be the better investment.
ludicrouz
i have a gaming PC, able to run everything on max. Long term definitely PC saves a lot more money. With all the game discount sites.
But I am still getting the PS4 for console only games. 2 of the examples are FF15 and Kingdom hearts 3.
And also have 3 PS vita to go along with the PS4.
For me, PS4 is for console only games, and also multiplayer games when u have friends over to play together.
zul99z
If you want a 1.5k setup with everything and with tight budget. Go for tradepac and be stern with what you want from the list. Make sure be there to monitor them what they do.
1.5k everything in.
Asrock b75m dgs + i5 3350p ~ $ 271
Adata 1600mhz 8gb ~ $ 85
WD Blue 1tb ~ $ 78
Silicon power v60 120gb ~ $ 120
Gigabyte r9 280x 3gb ~ $ 425 (bizgram)
Superflower golden green hx600 600w 80 + gold efficiency ~ $ 109 ( mynextcom )
Coolermaster 311 chassis ~ $51
Windows 7 home premium 64bit ~ $ 115
Samsung odd ~ $ 21
Dell s2340L 23inch ips gloss panel ~ $ 215
Logitech kb and mouse combo mk120 ~ $18
Total $1508. Buy at tradepac. Diy.
Hi there again. Thnx a lot for the recommendations. I`ve read some articles on the parts that you have recommended, all seems good especially your gpu. However, i have some questions for you.
1) Why choose a i5 3350p processor? Read that it`s based on ivy bridge, aka last gen so i dont think its future proof for the next 2 years right? :eek:
2) The ram supports up to only 1600mhz, why not choose a higher speed, the higher the clock the faster and smoother the computer runs right?
3) For the ssd based on what i read, its good value as its cheap. However, there have been complaints that the write speed is slower than advertised (around half the speed after a few months of use). Should i be worried? :o
4) I want a casing that has a side window, just for showing off hahaha:s13:
If need be, i can add in $100 more. Planning to get the rig on the second week of december. Sry for asking so much questions and i don`t mean to be offensive to anyone. And i`ll be getting a psp vita 2000 to play the playstation exclusive games so my mind has been made up to buy a pc. Happy evening everybody :s12::s12:
royfrosty
If need be, i can add in $100 more. Planning to get the rig on the second week of december. Sry for asking so much questions and i don`t mean to be offensive to anyone. And i`ll be getting a psp vita 2000 to play the playstation exclusive games so my mind has been made up to but a pc. Happy evening everybody :s12::s12:
1. I5-3350p is the previous gen CPU. It is also the same specs as the i5-3470 just do not have inter grated GPU. Well if you think of increasing the budget of cause an MSI b85m g43 + i5-4570 ~ $356 will be a better choice. Newer with support for dual amd GPU in future if you need more horsepower. This CPU is the same speed as the previous gen i5-4570/3350p.
2. You can't feel any difference from 1600mhz onwards. Not unless you use benchmarking tools and*results wil be able to tell you the difference. Else to a naked eye you can't see it.
3. Silicon power is a budget ssd. Good for people whom have a tight budget. If you want can considered a plextor m5p or corsair force LS.
4. CM311 has a side window panel. But if you want more attractive chassis can consider the fractal design r4 with side window or my personal favourite corsair carbide 540 air.
zul99z
Hi guys, have saved up more money and have 1.8k to spent now. I need a full rig reccomendation, including a dual band network card, kb, mouse, monitor, speakers and some led. Is it posssible with my budget? :o
m3 th3 last
Look around the threads or a few other, there are alot of recommendation going on.
But basically, to answer your question yes it is possible to get a good rig going with ur budget.
Lastly, is there any thing if u like to re-use from your previous rig? E.g. HDD, since it's a new rig u would have a SDD for primary drive, y not through in ur old one as storage purposes? Save some cost in between. Such items that can be re-used are not much, DVD -Drive, Casing if u dun mind the same look.
That's my money saving tips i guess.
royfrosty
1.8k everything in.
Msi b85m g43 + i5-4570 ~ $348
Gskills ripjaws 1600mhz 2x4gb kit ~ $110
WD blue 1tb ~ $77
Plextor m5s 128gb ~ $135
Gigabyte r9 28x oc 3gb ~ $425
Superflower hx600 600w 80+ gold ~ $109
Fractal design arc midi ~ $129
Samsung odd ~ $21
Dell s2340l ~ $219
Windows 7 home premium 64bit ~ $115
Tplink n300 wireless USB adapter ~ $45
Total $1733. Buy at tradepac. Diy.
Remainder for any speakers you like.
zul99z
Had a look around, here`s what i found for my budget.
i5-4570 + Msi b85m g43 ~ $356
Crucial 8gb ddr3 ~ $90
Wd blue 1tb ~ $78
Plextor m5s 128gb ssd ~ $135
Msi 280x tf ~ $450
Superflower hx 600 ~ $109
Samsung oem drive ~ $21
Fractal design arc midi r2 ~ $130
Win7 64 oem ~ $115
Dell u2312hm ~ $245
Logitech ls21 speaker ~ $27
Logitech g100 gaming keyboard + mouse ~ $48
TP-Link WN851N 300Mbps Wireless N PCI Adapter ~$45
Around $1845. For led i guess not necessary so not gonna get it. So is this the best value rig for my budget? :o
zul99z
1.8k everything in.
WD blue 1tb ~ $77
Samsung odd ~ $21
Dell s2340l ~ $219
Thanks bro, any speakers to recommend? Not sure which is good for a budget of around $70????
