Paul Lee
- Jan 1, 2000
For a first timer, the first thing you really must do is to get the membership. You know where to get this.
Here's a tip I dun think has been mentioned yet. Bring your Spore NRIC to register your Genting card. Why? If you used your Passport to register, when you passport expires, so does your card. So you will need to get a new one every 5 years. If you use your NRIC, your card will not expire as long as you remain 'active'.
If you dun like to bring your NRIC overseas (like me) and dun mind changing your card every 5 yrs, then using the passport is OK too.
After you get your card, go to the kiosk and check for freebies. There would probably be a few for new signups. Just explore the kiosk for Rewards or Earn and Redeem.
Sometimes you can get NN credits and free meal vouchers. On your birthday month, you get a (slice) of cake too.
For the non-negotiable chips (that comes with the free meal voucher and GP) aka Golden Package, this is what you need to do.
#1 Go to the membership counter and tell them you want to buy the Golden Package.
#2 Be very clear whether it is for table game, Electronic game or Slots.
#3 Choose from $300, $500 or $1000 package. You can only buy one package a day. The daily cut-off is 0430 hrs
#4 You will get a few receipts including meal vouchers and other offers.
#5 Go to the cashier inside the casino (there's one on L2). Hand the receipts to the staff and pay them the amount. They will validate your meal vouchers (or it will be useless)
#6 If you are playing electronic game/slot, the credit will be credited into your card. If you are playing table game, you will be given another voucher.
#7 Take this voucher to any table game with a scanner (most located on L2). Hand over the voucher and your membership card to the dealer. They will validate and hand over the NN chips to you to play.
#8 Tip: Check to see the table has a scanner and the dealer has the required NN chips before requesting for change. And you do not need to change at the table you want to play.
#9 Note: NN chips can only be used at Sky Casino common area. It cannot be used at the old casinos or Silver room (presume Gold also cannot used)
I know the above sounds complicated and tedious but you will get the hang of it after a few times.
Any other questions?
