Google Pixel 5a with 5G
limmk
pixel features also limited.
Ya man still no call screening ... neck long long ... and will never come ...
xonix
Definitely skipping if only upgrade is SoC ( SD765G )
limmk
https://www.gizmochina.com/2021/07/...el-5a-5g-will-have-snapdragon-750g-processor/
According to the Indian blog, Trak, the Pixel 5a 5G will drop the Snapdragon 765G for the Snapdragon 750G. One of the key differences between the two chipsets is that the Snapdragon 750G is built on a slightly larger node (8nm) than the Snapdragon 765G (7nm). Another major difference is the CPU. The Snapdragon 750G has 2x Cortex-A77 cores clocked at 2.2GHz while the Snapdragon 765G has 1x Cortex-A76 core at 2.4GHz and 1x Cortex-A76 core at 2.2GHz. The remaining six cores on both chipsets are Cortex-A55 cores clocked at 1.8GHz.
As you can see, while the Snapdragon 750G has a larger node, its CPUs are more powerful. On the other hand, the Snapdragon 765G has a smaller node size for better efficiency and power consumption but less powerful cores.
https://nanoreview.net/en/soc/qualcomm-snapdragon-750g
https://nanoreview.net/en/soc/qualcomm-snapdragon-765g
