How is coarse grinding performance ?
I just tested this with a v60 this afternoon. 16g of coffee takes less 30secs to grind. Faster than a porlex... could be due to the larger burr set.
From a very unscientific experiment particle size wise its more consistent than the porlex. There are no boulders. Fines are still there but seems less than the porlex....maybe the blunt ceramic grinders of the porlex produces more fines? I used to get choking on the v60 from using the porlex due to the fines.
Less fines than the HG one too..hm...maybe large conical produces more fines? Longer grinding path..
The feldgrind is finally here! Solid built quality and well designed. pulled a 1st shot at their recommended setting and the pour came out perfect! 18g dose for a 30g shot.
Look at the pour!
There are some cons though. Not as easy and fast to grind as the HG One. The setting is also very sensitive. The HG one is more forgiving, 1-2 notches on the setting dial hardly makes a difference to the pour rate. For the feldgrind I got a gusher just by turning the dial by 1 number from an acceptable setting. Are large conicals more forgiving? I don't think so. I think the smaller turning radius of the setting for smaller grinders makes small adjustments more exaggerated in their effect on the grind size.
Overall a value for money product for 200 bucks. Highly recommended if you don't mind the long wait and non existent customer service. Makes a good portable grinder for outdoors, camping or on the move, small and rock solid. Beats the porlex to pieces in terms of build and grind consistency. Pair this with a v60 and good beans and you are good to go!
I'm using a hario slim. When I coarse grinds it's not so consistent, if I use the sift to filter out the finds. Would it be "good enough"? Don't need to reach A+. A can already , if you know what I mean.
how's this compared to the lido 2? Which would you recommend?
Depends entirely on your needs!how's this compared to the lido 2? Which would you recommend?
congrats on your new hoot! How many shots did you have to dial in to get that pour? And what is your redistribution method like? Any in-the-cup difference with the HG One?
Anybody on here wants to buy a lido 2 or is buying one can we buy together to save on shipping cost? one lido 2's shipping cost 58 usd but two costs only 73 usd. who wants to share shipping!!
I'm waiting for my ROK espresso grinder. Anybody else bought it as well, think gotta wait for at least 6 months before it arrives. Bo bian have to use hario skerton for now![]()
waiting for ROK too. currently using a cheap electric grinder + porlex to do the job.
I think earliest also need half a year of waiting time![]()
Does anybody know if the aeropress makes espresso or regular drip coffee akin to the french press for example?
