testerjp
- Jan 29, 2006
Ok, normally when you dose into your PF, do you just level off the grounds? Or do you grind by weight?
Ya I saw zero bar and I was shocked. I remembered tamping quite hard, although I'm not sure if it was 30 lbs. I'll try going much finer first, if not then adding more grounds
Since you just got the machine, start that time use weight to get the first point right will be much easier.
You may also want to do single dosing if you have a weighing scale and don't drink a lot. Go google tat.
I don't level off, I use super fine grind setting and normally use medium-dark roast.
Cuz my singles are abt 7g, doubles 15g, it won't reach that height to level off too.
Since my grind setting is very fine, I do very light tamp. I use my index finger and middle to push down imagine that, no body weight, i think less than 5KG. No funny methods, no problem with channelling.
If heavy tamp, it gets stuck
But i tried before, if you intend to use coarser grind, and use mad crazy of coffee like 20g, it's better to tamp harder.
Also, every few days sure have to tune the fineness or the dose a little cause the coffee will everyday deteriorate a little from oxidisation.
When you tune the fineness, which is the size of the particles, the weight will be affected so no point chasing the moving target, your life will be very difficult.
P.S:
1.After you tune the grind setting, you must grind n dump a little to get rid of those powder from the previous setting.
2. If you intend to throw all your beans into the hopper, dump a few grams of coffee before you first cup in the morning. That is to get rid of stale coffee stuck since your last cup.
3. If your coffee is crap and stale, no matter how you try also won't have thick crema. No need to be a cremahead though.
by the way, BZ13 is on a 3 way valve? so backflush is simply put blind filter and run water for how long? How many cycles, say for a daily clear water backflush?
BZ13 has 3 way, flush with blind filter until it pressurise, it should reach around 12 bars then stop, go 5 cycles. Less than 1 min job.
