tortoise18
- Apr 18, 2005
Starbucks beans cost how much in sg? Im thinking to order from amazon
Upgrading from Silvia + PID.
1) 2 cups a day max
2) Latte drinker
3) Budget sub $1,500 ~2,000
4) Easy to use
5) Prefer to buy overseas as it's overpriced here.
Any advise?
Already have macap grinder.
How easy to use? Same as current?
Or you can wait for reviews on these
https://decentespresso.com/dem_buy
Or get E61
https://www.espressocoffeeshop.com/rocket-appartamento
I’m ok with current of course not those press one button de .
No need to wait as in between frothing like the Silvia
It's no longer worth buying from overseas given the current FX rate Eur 1 :SGD 1.6x.
Add the GST, add the freight charges.
Can cost even more, especially the Bezzera
Not to mention, zero warranty for overseas units.
Price of that with GST can buy a Bezzera Mitica with PID and rotary pump liao.![]()
Buy my strega so I can upgrade!
You already have a Strega. what’ve what upgrading to? GS3 MP?
HB and German coffee forum talking about the Slayer has some design flaws.
https://www.home-barista.com/espresso-machines/slayer-single-group-risk-of-leaking-t49003.html
https://www.kaffee-netz.de/threads/slayer-erfahrungsbericht.102810/
Think if you have a lot of money, can hold back and wait for the LM La Curva, look like LM is really going back to lever.
Looks very good but also very complicated. Must be very costly for servicing
Linea Mini or GS3... if only the GS3 is priced similar to what the Linea is now..
The LM Leva, too complicated for its own good, most likely a novelty machine that 99% can't fully use any of its function.
Unless there's specialty cafe that allows people to consistently try out different variation, but the concept itself is a costly venture..
I actually read the German thread again.Read the thread carefully.
This is simply a case of a clueless user who did not set his expansion valve properly leading to a blown gasket. He subsequently panicked and posted on home barista and German forums.
Fail to set the expansion valve properly on any machine and your will get the same leakage.
The main problem with the single group was with temp stability in the early version. That was fixed with a firmware upgrade.
Some goes for any machine. Buy it only after 1 year after commissioning. Don’t be the first user. Hint: don’t buy the LM leva yet.
Google “<insert machine name> + problems” and you will always get results, mostly from more clueless users making honest beginner mistakes.
