(GPGT)Espresso machine hoot
compuser
It is fast, but its not dry and powerful enough for silky smooth milk.
Initially, I can't get it right too, but I found out my method was wrong after going for a barista class.
My HX is just 1.5l, even smaller than your Strega.
My latte cups are about 180ml, still alright for two.
From what I researched back then, the steam power depends on the size of the boiler and the temperature. Linea mini's steam is definitely more as the boiler is 3l, use much more power and cost 3x more though.
Knight_Rider
https://www.deathwishcoffee.com/collections/death-wish-coffee
tortoise18
I gt this espresso hand grinder. After 3 uses, it suddenly stopped working. Without coffee bean, the burr turns. With coffee bean, the beans keeps getting stuck inside. The burr stopped turning. How to solve this? I dismantled and assembled again, no diff
testerjp
suddenly USD dropped to like 1.31. Buy local still cheaper or overseas now?
They are priced in Euro. Like a car, you will need regular maintenance and strong local support. It's not a one time purchase thing.
I suggest that you go and try the machines yourself to know the differences between different groupheads. Personally, I like the Bezzera Strega most but it's out of your budget. :o
Where can try ah?
testerjp
They are all okay or more or less abt the same as the Bezzera Magica.
Appartamento no brew pressure gauge.
Tank and boiler abit smaller.
You happy can liao.
Any choice also better than your single boiler now. :o
You happy can liao.
in this case get the cheaper HX la which is BZ10
patryn33
You considering American made machine? These come with 220v
https://decentespresso.com/dem_buy
If not they are prices in Euro, u don’t want to buy 110V from USA and get transformers cost more
Limited budget bz10 is better than what you have today
If u kept thinking spend little more can get that and a little more can get Y. Never ending
Yeah I feel also neverending de. Not sure can know the difference or not when drinking. I'm using the Macap MC6 at home, should be ok hor
Quote first
Highlander carries Vibiemme
Chye Seng Huat and 1 more shop (check back on thread) carries rocket
Necessary provision carries Quickmill
Fine Coffee Company carries Bezzera and Expobar
Jimmy monkey carries Slayer
Spinelli carries Rancilio
There's more other forummers can tell you I think.
To be honest, I checked all these before I purchased. So far, Bezzera from FCC is the cheapest. No I am not related to them, just sharing what I went through you are thinking now.
*edit - rancilio is cheapest, but it has its own differences
patryn33
65mm burr good enough.
most ppl cannot tell the difference. the quality and freshness of beans matter more.
genie47
Some superautomatic love here. I'm stuck with superautos because wife is a convenience person and yet wants good coffee.
The most popular models around are the DeLonghis of which the ESAM3300 is the cheapest. I believe you can get it for aorund SGD500-600.
Of course you need to maintain it well. Videos for the cleaning and maintenance of the brew head can be found on Youtube. Parts are easily available from eBay and many other retailers.
Got my ESAM6600 for a measely SGD400. Been going on well. In the office I have a Solis Palazzo which is basically a Gaggia Titanium in disguise.
Every time I maintain it, it is like strip rifle time. The brew head comes out and a lot of "click-clack" sounds. I save money by not getting specialty coffee machine cleaners. Being well-versed in chemistry, you want something alkaline to convert the oils into soap through saponification and make them easier to wash off. I use washing soda which is basically sodium carbonate (not bicarbonate).
seianko
Suspended
shyly ask shoo shoo where u buy ?
