tremor
- Jan 20, 2001
I've tried the Oscar, i find that it runs very hot, I was trying with an Ethiopian blend and the flowery notes are almost all burnt out.
IIRC the modified version which can run it slightly more stable and cooler is $15xx. But still there's no gauge that tells you the status of your brew or boiler pressure.
I suggest get another model unless your budget is really tight. E61 is imho more forgiving to use.
Sadly for my budget there is no heat exchanger or dual boiler with pid.
I was maybe thinking of saving up more and hoot the lelit Elizabeth. Got electronic dosing.
