Curious to know, how this fix related with marketing team ?
they never fix it, as long as you are using full hd, unlikely you will hit into the problem with current titles.
Mind me asking, so for the free new tom clancy's game that came free with various gtx970.. can i assume there will be no issue playing using dell u2312hm monitor..?
no problem with your current monitor.
1440p cannot lah. Lol. The other time when i was trying SoM it is playable but 30fps range nia.
I set to high also still not smooth.
1440p minimum 390x liao.
Like other has mentioned. If you playing at 1080p resolution. Chances are you will be fine.
If you intend to play on higher resolution, you will need to sacrifice other kind of grapphics settings. You might need to turn down a notch or two.
At this rate of games we are going, most AAA 1080p titles will probably take between 2gb-3gb. Some worse optimzed games can take up to 4gb.
GTX 970 got problem meh. Rock solid dude. Wont go wrong. If your are referring to the scandal that the rest have mentioned, there is no way to fix it. its an "error" in marketing. Anyway, I would hold off, since polaris coming out soon! Adopt a wait and see approach if possible!
if really mind wait new model appear
Buy a better graphics card if using higher than 1080p resolution.
Actually, the issue with the scandal is already fixed. Nvidia misrepresented the product and they have owned up. Hardware wise, its permanent unfortunately.
The GTX 970 should run most games at 1440p based on my understanding. The main competitor being the AMD R9 390 8GB, is also a great card to consider.
You intend to play any DX12 games?
well I agree, but still probably just gonna replacement for a dead gpu that's all
I know AMD isn't that bad, but im wondering can my system support it?? As for that 8gb vram i think its beyond what i need xD
Well ofc, but not sure if any dx12 games are my favorite atm
And I have recently purchase my Need for Speed 2015 edition...not sure if it will become dx 12...even though system requirement is only dx 11
Yes it can run most games at 1440p as long as it uses less than 3.5 gb of vram.
But once it hits above 3.5 gb, the fps will drop and become barely playable some certain titles.
So chances are you will not want to set to the max setting, then what is the
point of getting it?
Sorry guys I change my mind on getting GTX 970.
Now I wonder if I should get GTX 960/R7 370/R9 380(with or without X)
Since if i dun want to think of any problem that could occur while playing.
GTX970 3.5g issue is the reason why I went GTX 980. I wish I could have GTX980 Ti but I have limited budget. GTX980 is actually the worst price performance ratio compared to many. Just get the cheapest one if you are on budget if not 980 Ti is way to go now..
Would rather buy a used 780Ti instead..buy 980 used then it will be very value for money lol...thanks to 980 ti
