osirisx
hm... when I visited there last week, there's a shop with bunch of old uncles sitting outside chit chat and coffee. Ask the shop owner also said dun have. But that time most of the shop are closed... perhaps I miss that...
oh ya, may I asked, you mentioned you got your rivets there, is it for model kit or something else?
Thanks!
those are just small screws that I intend to use as rivets for my gundam kits....quite a big selection, can take a look around the shops
or if really cannot find then just get those 3rd party gn drives led and use the screw for it
Zephon
thx bro... mind to share with me how to get '3rd party component'/ GN drives in singapore? (hope it doesn't requires me to buy the entire box... :S)
osirisx
back then I ordered mine from ebay & samueldecal(cheaper than local) and just bought the leds from simlim tower to make it as bright/brighter than bandai's one, not sure if samuel still sells them
locally....iirc hobbykulture sells them(1 set inc battery), though if you're concerned about the price...I would suggest looking around simlim tower first for the screws, much cheaper
Zephon
ok... look slike i have to pay sim lim tower a second visit... should go on saturday then. (last week i went on sunday, may be that's the reason why most of the shop closed...)
Blusttoy
Regarding AGE episode 30:
E.F.F were without a doubt useless in previous 2 generations but in this one, they're utterly hopeless. It's understandable that the command's chaotic with the destruction of the Big Ring but to continue having EFF grunts doing minimal damage to Vagans is just sad. The teamwork displayed was very impressive though, gives off Unicorn OVA vibe.
With exams over, I've been trying to get back into Gunpla groove but the post-exam moody feeling is making progress slow. Anyway, I finally got my ass off and started the Banshee.
The rest of the time was spent playing noobly around with iPhone image-editting apps, namely PEStudio and Easy Titler.
