ongkh2000
Huh? What is pigments?
what sliver is trying to say is for you to practice on ur basics such as removal of nubs / sanding etc. shading/weathering is an advanced technique. no point concentrating on weathering if your basics are not there. my sgd 0.02
tanyieern
Nono, im just looking for additional knowledge. Not intending to do anything related to shading in the near future. Thanks anyway.
aucheukyan
Tamiya weathering poweders are so expensive, buy 1kg of pigments from airfriend is like only $20++ :vijayadmin::vijayadmin::vijayadmin:
Shinizan
1 Tamiya weathering powder is about $12+? And they have so many sets of color to boot. I remb reading somewhere that 2 sets (forgot which sets) are all that's is needed for gunpla.
flanker27
Serious. Use sandpaper to grind crayons into pigments n apply accordingly
it is not called crayons for sure. if i am not wrong, it should be artist chalk.......need not use a sandpaper to grind it down. you can alternatively use a pen knife or blade of some sort to scrape it off.. then apply it accordingly to the model with a paint brush.
tanyieern
Hi, anyone knows where else can i find tamiya paint other than stargek? I refer to all types( spray, acrylic, enamel etc.) i think HAW sells acrylic, but not very sure.
Thanks:D
noForm
Hi guys I need some help. if i use arylic paint like tamiya X7. i use water to mix what is the ratio needed?
aucheukyan
Thanks:D
MWS, hobby point sells most tamiya ranges
should be called pastel sticks or chalks.........
for handpaint is around 1:1 paint to water, consistency is like calligraphy ink like that
for airbrush i use X-20 A thinner 1:2 paint to thinner, or 10% magiclean/water solution 1:1.5 paint to solution.
