thegamer1907
done another kit:
this time i used ZiG millenium 0.05 marker with gundam marker for panel line.
The ZiG marker is good for narrow spaces.
only around $2 at popular. the ink is kinda watery like the enamel wash like and is easy to wipe away. once it dries it wont be easily wiped away
still waiting for the decals.. my hands itching to use the can of Mr Super Clear topcoat already.
wanrong
Hi, bros who recently came back from Taiwan would you mind letting me know how much is a MG 00 raiser & MG Sinanju .
Going to Taiwan next month but wondering if its any cheaper( can save the hassle of carrying back if almost the same.)
:o Thanks !
wanrong
Hi, anyone know if the Orchard store still operates? Where does it move to now?
Would like to get some testor enamel spray cans, or anyone knows where else I Singapore I can get enamel spray cans please do let me know :o
rookierocky
what shop u referring to
thegamer1907
the water slide decals arrived today.. all was well til i realised the rx78-2 decals were not pre-cut. my bad for not confirming with the seller, really tough to cut out the exact shape and trimming the excess for someone who never used water decals like me..
thegamer1907
all done after working the whole day.
but of course, mishaps do happen =/
after adding decals i proceeded to topcoat the torso first, little did i know that on the first spray, a large spurt of the solution came out, seem like the pressure was too high. This caused a milky effect on the front part of the torso =( to salvage it i scraped the parts off but that left a large mark, lucky though from far not too obvious.
the affected part:
more pics:
aucheukyan
the affected part:
Should have use a runner to try spray first, or you can buy a plastic spoon and try spray(dunno who said so, but credits to him)
AikiBoy
Watching season 2 00 on youtube gundam info
after 7 years... I finally know how to appreciate 00.
on a neutral mindset, not siding which gundam from other series is nicer or MS design better. :s13:
used to think... y put 2 engines on the shoulder.. if im the enemy Ill just aim both shoulder...
hope they upload gundam X
thegamer1907
yup, had to learn it the hard way :(
after that i had to spray few more bursts for the pressure to decrease.
Did i buy a old can? next time i will check first every new can..
Blusttoy
Nice that you're going to the decal stages and all.
But about the white effect, I believe it's frosting, and you could have fixed it through other methods without damaging the topcoat/decal/layers. Happens when I spray topcoat after a rainy day usually, there's other reasons too like the can is cold or something.
For example, I will spray gloss coat over it and others would airbrush thinner if I'm not wrong.
evilerniex
the affected part:
more pics:
for decals that go over panel lines, such as the big one on the shield, u shld do the panel line after putting the decal. i.e. the panel lines shld still be showing and not covered by the decal.
this is because panel lines represents the gaps between 2 plates of armour. so there shldnt be any decal 'floating' on these gaps
unicr0ne
the affected part:
more pics:
so much frosting and your decal never use mark setter and softer?
can see the edges and your plastic surface frosty like top coat fail.
