tissuepaper
Hi guys. I just bought a can of topcoat. Need some advice.
Is it safe to topcoat at night? I understand weather will affect the quality. Will probably leave it inside the house to dry. OK? Or too cold?
If can should I leave it in a ventilated area or in a room with the windows closed? Or air conditioned room even?
ventilated area always. no air con.
best dont topcoat at night. just coat during day time. best result imo is coat under sunny day.
cocopuff
Thanks for the info! Wanted to leave it overnight to dry since I only have time now for today. Roughly how long should I leave to dry? I'm afraid it rains halfway (weather in SG crazy nowadays) and it'll affect the finish
jazy1992
top coat very fast dry de, especially when u are using mist coat.. wait for 1 hr should be fine enough
chompchomp
Where to buy the gundam pre coloured ones cheapest.. I only know og.. Want to get the S grade (gold) iirc..getting as gift no knowledge at all for such.. Any advise thanks
jazy1992
define pre-colored. all gundam models are molded in colors. as for S grade i have no idea what u mean
JulyStork
Wah panel lining is making my blood boil:(
Can anybody recommend any pigment ink markers for HG kits? I find that even Gundam's markers the ink dries out too fast
jazy1992
get the oil based panel line marker or the enamel wash gundam marker pen?
cocopuff
Anyone knows of any gunpla shops in the east, apart from hobbypoint @ century square? Preferably near Eunos.
Looking to get Action Base 2.
evilerniex
complete this recently
yuichiroyt
hey guys, i'm doing my first top coat tomorrow. is it necessary to top coat them by parts, or just assemble then spray whole hting?
-EnZo-
Noob question. I have just sprayed my gundam with tamiya can sprays after that how do I panel wash it ? I cant use thinner to clean the smudge right? Btw im using tamiya enamel black panel line. Do I gloss top coat it 1st? Or die die hv to use marker?
evilerniex
either way is ok.
if assemble and spray, just need to ensure that all exposed parts are topcoated.
i usually partial assemble then topcoat. e.g. assemble the entire arm and topcoat as one piece
evilerniex
tamiya spraycans are usually lacquer based paint, whereas for panel wash u are using enamel paint. enemel thinner will not affect lacquer paint.
if ur paint is gloss, then u dun need to gloss coat it again. else it is better to gloss coat so that the enamal wash flows better along the panel lines and is easier to clean off with enamal thinner
evilerniex
what airbrush u use...
i am using a hobbymate airbrush
but y u need to know wat airbrush i using? :s11::s11: almost any airbrush can achieve the same thing as wat i have done, even the cheapo china ones that cost less than $50
AikiBoy
I noob in airbrush. n I stopped for 2yrs... itcy to do kits.
