evilerniex
its nearby for me tbh. if i can ditch the missus i will drop by, no need to give advance attendance right?
membership is $25 per year.
but u can just drop by take a look and see if u are interested to join
evilerniex
am intending to restart my blue frame.
am intending to do a chrome frame with clear blue, should achieve a candy blue kind of color. Question is if i matt coat in the end will it dull the candy frame? Cause i intend to matt all the whites/armor. Not sure if glossy frame + matt armor would work
matt coat will dull the candy gloss.
candy gloss frame + matt armour sounds alright. u can always try that first and if not happy with the outcome, then just matt everything.
but I suggest u try out matt coat on candy gloss on an unwanted part or plastic spoon first to see the effect
NeonX
there are blue parts that are on the weapon on stuff, if mix both coats i think its gonna be weird.
i intend to shade also, not sure if a chrome base, clear smoke for shading and clear blue would work. should probably got for a matt coat in the end
kenneth0601
guys. I’m looking for a place that can let me air brush properly with ample lighting. Anyone know to any place?
Sent from Samsung SM-N920I using GAGT
Can join us at Cheng San CC if you want to airbrush.
Last paint session setup.
NeonX
do you guys still order your decals online? or now got physical shop in sg selling already?
kenneth0601
Taobao has the range for 3rd party decals, local shops will stock the original Bandai decals, but stocks are very limited.
AikiBoy
anyone went to tamashii nation japan before?
was thinking to go there this nov.
s.freedom also out this month :D
I wonder how is the crowd going to be like...
Errz
thinking of getting this but how to order from taobao? open the link and saw they got a few options? my mandarin cmi.. so idk how to go about.. :s22:
u got taobao account ? if u use chrome, can do a translate .
Errz
Bryson
kenneth0601
There is a featured sponsor in EDMW, Skycart is a TB agent. You can check with them on how to go about with buying from TB.
I had a word with them yesterday about buying and shipping paint from TB.
May want to use them for my next major paint purchase.
Bryson
Just ordered from skycart after your recommendation. Their customer service responded very fast earlier today. Thank you bro!
But I kinda dislike the idea of topping up in their skycart wallet and be left with $3 lingering around in there if I'm not spending on anything more..
Sent from LGE LG-H815 using GAGT
Errz
tons of stuff to buy lor. dont think that will be ur last. :s13:
eg
dropper
mixing cup
alligator clips
foam block
airbrush cleaning tools
gunpla kits and many many more :s12::s13:
