brahm1979
guys, i need to buy some evergreen 2.6mm styrene rod for my project.
Anyone knows if Artfriend Takashimaya sells evergreen products?
Thanks in advance.
sliver0503
In this case, u can call artfriend orchard to enquire abt stock availability
http://www.artfriend.com.sg/locates.html
Spector1986
I m also using dh-103.. Don't be sensitive.. I not saying other airbrush not good.. Just saying wat I using..
brahm1979
i think u can put 'dun be sensitive' in your siggy :s13:
tissuepaper
thanks you guys for the input/feedback/opinions/suggestions for ab. :o
and seeing the noozle size of 0.2,0.25,0.3mm etc, does the different sizes affect way of ab? like 0.3 for normal use and 0.2 for pre/post shading? not sure myself about this.
aucheukyan
Don't listen to what other people said till you got a feels and test it out the airbrush yourself personal.
Before you buy an airbrush do consider the following :
Does the airbrush provide after sales service ?
Does you airbrush got warranty ?
Does your airbrush got spare parts to replace ?
Does the shop you buy from provide servicing for your airbrush ?
Does the shop you buy from give you a introduction course on basic usage of airbrush e.g.
how to clean your airbrush and basic guide ?
Do compare the trigger pull feeling for different airbrush before you decide.
Does the airbrush give you an option to change the Cup and Needle size ?
Hope this help you to choose your wanted airbrush.
Ed
Again its YMMV.....
i got a DH-102 and a Hobbymate HM135, i do use my hobbymate 0.3 for preshading, actually i just spam the black and the cover with whatever colour, max technique FTW:D
my sd rx example, and dont ask me about the mold lines on the poles, im too lazy to remove them and in the end it gets covered by the head and the arms=:p
my DH-102 is still sealed and collecting dust, not enough level and stats to use it..... level 30 item, i still level 1 only:(
Spector1986
My iwata hp-cp also collecting dust.. I can't equip it :(
The iwata level 300.. I only level 0.. Haiz.. Even a 5 year old can do better than me :(
alexmcqueen
iwata lvl 300 item I lvl 0.001 but I still using it. cos I equip the noob ring den u can cancel item requirement.
but the cons of the noob ring is item durability reduce by 800% :(
StarDus
I use Gaia moderate thinner for fluorescent clear. I use them for all colors which I want them to look glossy. as for super fine silver, I use gaia metallic thinner. dun haf any dot dot problems with it. looks very fine snd smooth. only mr super metallic super chrome sm06 I use leveling thinner, as like wat u saw on the link, it doesn't seem to dissolve in other thinners.
both sm06 and sm08 plate silver next I got them from online. but I did saw sm08 selling at hobby point. sm08 is pre thinned. and I would prefer it over alclad as it doesn't get rub off that easily.
as for fluorescent clear result, it's not exactly very noticeable. it gives purplish tint when u use it over. somehow I feel, it makes the metallic colors looks more 'metal' as compare to just normal gloss coat. for crystal colors, unless u use it over blue or silver, or some darker tones, else the purplish tint might alter the final look of the color. unless u want it intentionally. hasn't really tried b4 though. but I did tried it over gloss black and I got a black with purplish hue.
Thanks for your detailed reply! Already copied them onto my modelling notes.
Gaia moderate thinner is just normal thinner w/o (or lesser) smell, so I guess Naka thinner will do as well. Your link did mention dun use SM series with gaia metallic thinner, but yours are ok. I guess the link user just happen to try on the type (SM07) that can't use the metallic thinner! :s16:
SM08 is selling in hobby point?! Maybe I will dropby to take a look, long time never go there liao. I think the price should be quite 'nice'. Oh btw, Gaia apart from the light and dark stainless silver, I just saw that they have stainless silver! :crazy:
From what you said, I guess the fluorescent clear gives a purple (or maybe blue tint) so that it brings out the metallic or fluorescent color underneath it. (If you observe metal, especially stainless steel in mrt stns or in lifts, certain angle can see a bit of blue hue) So it should work for mr color/ crystal series as well. Oh no got to spend monies again... :s31:
Thanks again for your reply! :D
alexmcqueen
bro, gaia moderate thinner has retarder in it. so besides being less smelly, it also offers some properties of longer drying time and slightly more glossy finish. so it is almost the same as mr hobby levelling thinning.
as for the sm series paint, only sm06 ( chrome silver) cant be diluted with normal or metallic thinner. the rest ( sm01-sm05) works fine, if not better, with gaia metallic thinner. from the link i have given, the blogger was only having problems with sm06 with gaia metallic thinner. i tried it first hand as well. the paint just clump together, just like the pic he posted. so, use mr color levelling thinner for sm06 (recommended by the instructions on the bottle/box).
btw, sm08 ( plate silver next), i think costs $16 at hobby point :s27:
ongkh2000
yep i saw it there too.. expensive...
-___-
piecewise
progress on my HG Titus.. lol, one of the hardest seamlines i have ever removed. :s16::s16:
now just left with the other side. :(
