PlainBlackTee
not gundam related but need to seek you guys' expertise. may i know if i should use water based or oil based marker for painting abs plastic toy?
RedEyesFan
On the very safe side, just use acrylics.
Turpentine will "soften"/melt the plastic while lacquer will brittle the abs.
RedEyesFan
ok thank u very much
Since your use the word toy, you may need to use primer since acrylics aren't as adhesive as the other 2.
Lacquer paint should be safe if you spray a layer of primer on the pieces first since the problem is exposure to lacquer thinner due to wet paint.
Greenworm
thinking of starting but don't want too heavy on investments.
I on the other hand have to give up this hobby due to work, if you dont mind starting with lacquer paint, i can sell you my whole equipment dirt cheap, kits,paint everything lol
JulyStork
Dry transfer decal gone wrong
So can this be repaired or is it ruined permanently?
chillplz
do p-bandai kit ever have a re-release? i am looking at amazing exia mg will they ever release the kit again?
Blusttoy
Decal is ruined but overall situation may be salvageable.
Apply the remainder of the decal and then touch up with permanent fine tip black marker.
Zephon
Guys I need some help, I was building my high resolution wing gundam and and I lost the right thumb.... :s22:
Can someone advice me how to get the replacement part? I knew the replacement part service only available in Japan :(
RedEyesFan
cast it from the left thumb?
RedEyesFan
wow bro it sounds super advance to me, I did a search about gunpla part casting, and found this:
Is this what you talking about?
That is too ex for a bloody small part.
Get some blue oyumaru and epoxy putty.
kaixax555
First build in a good while
My backlog just increased :sad:
Sent from AKB48 theater using GAGT
