Help for a new DIY PC (1st timer)
Palaxius
Sometimes paying more does not mean better, therefore I'm asking if there is a difference in performance for the SSD if I am buying a more expensive brand.
ZrE0_Cha0s
if that is so, May I ask if are u running any heavy program like Photoshop or video editing or software rendering like 3D autocad or another similar?
if your main purpose is for booting OS, load some program fast enough or just games loading fast.
1st option SSD getting a premium SSD like Samsung 950 pro can great helps them reduce the waiting and getting more files to be updated promptly.
2nd option SSD is like getting a normal SSD is more than enough for these kind of tasks.
But let me tell you that 2nd option SSD still can do what 1st option SSD task just that not that fast enough for some people.
ExArchz
Which brand and model u comparing with?
ExArchz
TBH. U should take ZrE0_Cha0s's suggestion into consideration. Really consider the SSD that suits your requirements rather than worrying about paying Premium or not.
Since u are going to do video editing and stuff. A little google search will tell u more details on SSD benchmarks and what seq read/write and random read/write are. These details will help u decide which ssd to get.
xiaozozo
looking at opening post, at $2.5k budget, should try and fit in a 1080 card and maybe a fan cpu cooler.
CD drive can save $$, just buy a 8gb usb from cybermind then download the win10 installation into the usb for installation. The Win10 cdkey, up to you where to purchase, online or from shop which is OEM keys.
HDD for WD black, unless really needed that $200 can easily get same capacity for WD blue and the aftermarket cpu cooler, hyper 212 or anything u like. Just my 2cents :)
lucaslyh
Yea thats makes sense, btw, isit necessAry to get a aftermarket cpu cooler for something i wont OC? Will it usually overheat during normal usage?
I wish i could go for a 1080 too, but i dont really know where to shave off for an additional 400 to get one. Mayb can suggest.
ZrE0_Cha0s
ya u can get a aftermarket CPU cooler. there is no restriction to you not to get. it just that some of us find that not worth. but if u want to get its still fine.
how normal is ur meaning? gaming at most 60~70 depends on what games as well. but if like normal website, stream videos it also wont hit 100...at least 50~60 or could be lower depends on your cooler as well.
but which GTX 1080 are u going for? beside that maybe u can relist the parts and the pricing for it?
lucaslyh
ended up buying from tradepac,
got a sharkoon dg7000 instead of a nzxt s340
ripjaws ram instead of crucial ram
evga 650 gq gold psu instead of corsair cs650 psu
and added a asus PCE-AC56 wifi card
kept the msi gtx1070 gaming x for the fans
total spent 2340 for entire rig, not sure if could be cheaper. TBH wanted a refund after paying for the win10 oem, as my friend could help me with flashdrive craeation. tradepac boss wouldnt allow any refunds:( , could have saved another 150.
pretty good experience for first time building, just abit issue with win10 recognising the gpu.
thanks to all bros for answering my queries and giving me suggestions, appreciate all of your help alot :D. Just wondering where do i go to for EVGA psu warranty, i cant seem to find any singapore distro for it :s11: .
ZrE0_Cha0s
Wow u mean your friend can give you his win 10 for free?
Anyway for parscal GPU shouldn't be any issues. U can just download nvidia driver to get it to work.
As for EVGA, I dun think u need to register and our local distro is Tech Dynamic.
But case they reco nice meh? But PSU is good.
lucaslyh
case comes with 3 fans, looks pretty sturdy bt abit spacing abit tight for a newb building, i ended up bending my chassi fan pins pretty badly because of the wire positioning and length(URGH!). As well as case usb to mobo wire was rather short and they combined usb 3 and usb 2 connection points together, end up i could only fit the usb 3 points, usb 2 points could not be inserted at all.
im not sure if they gave me a much cheaper PSU than what was requested though(superflower leadex gold). Bt at that point i was so confused and just agreed without googling.
for rma of psu, i can just bring down to tech dynamic without registering ah?
ZrE0_Cha0s
lmao that casing...u should have asked them for another case similar to s340 but quality or build is some where there.
well i dun think so is cheaper one cos some for the EVGA PSU uses SF parts as well or the other way, cant rmb. u can search around this hwc to find out more on EVGA, and its widely reco by most builder who had purchased parts from amazon.
well from what i know from my friend he just bring down and do a exchange for his SF psu, so i think it applies to EVGA psu as well.
lucaslyh
ohhh but i dont think this evga model is made by superflower, its however made by FSP, do they still do warranty for non-superflower models?
i kind of bought one of their bundles whereby it comes with a sharkoon t28 case and superflower leadex 650 gold, both out of stock and wanted me to top up 95 for a s340, and swapped to the evga psu, i didnt really want to fork out another 95 for just the case alone.
ZrE0_Cha0s
u mean tech dynamic? yes they do warranty for it.
Krabs.
G2 and P2 series from EVGA are superflower leadex rebrands without the white LED and add the ECO mode switch
other alphabet series from EVGA I dunno made by whom .... don't want to find out too ... lazy :s13:
clearsky7
Mind giving a breakdown of your spending?
Kiwi8
Deluxe Member
Wah seh the budget is rich. :D
It's been a long time since I did another DIY rig on that budget. :o
lucaslyh
h170 pro gaming + i7-6700 - $640
msi gtx1070 gaming x - $810
sharkoon dg7000 + evga gq 650w - $220?
g.skill ripjaws 16gb ram + samsung 850 evo 250gb ssd - $220?
wd black 2tb hdd - 175
asus pce ac-56 - 90+
dvd reader- 20+
win 10 - 150
total 2340, i cant really remember exact price for the parts, and the really bad invoice layout from tradepac which doesnt give price breakdown isnt help either.
Krabs.
that 1070 overpriced by $300 .... add $100 more can get 1080 with online coupon
