[Help] My PC cannot start
zueinder
Used to work in SLS computer shop. If PSU not spoil, then check capacitor for black or bloated one, which most proper PC repair shop can do with welding tools. Then after that is use spare equipment to test each part 1 by 1. RAM,CPU, CPU fan, cooling fan, graphics card, hard drives, any cd-drives, any external accessories like fan controller, etc etc.
harbinger255
Welding tools??? You sure you work in PC repair shop?? :s14:
orpisia
Emeritus Honorary Member
Wa really technical sia and hands-on sia
BlackWing1977
No need la thanks for the offer
It's been operating for 12 years liao
It want to uplorry now also understandable
Time for new PC lar... really... you use it for gaming or general use only... if it is general use only easier to buy a miniPC...
Vanyel
Spare parts as I leftover mb gpu CPU from my last upgrades
Should be still way faster than what u had
Vanyel
Ryzen 2600X if u interested let me know
Along with ddr4 ram gpu mb
U already have casing and psu liao
Can sell everything to u cheap cheap
Arbo rotting in my hse nia
DragonFire
All 3 fans (1 exhaust, 2 fans in front) spin for 1 or 2 seconds then stop
Sounds like motherboard sending power not good to PSU? It may be worth tearing the motherboard out of the case to see if anything is dead behind the board. Like a lizard shorting things to GND.
articland05
The Intel Core i5-3470 was a desktop processor with 4 cores, launched in June 2012, at an MSRP of $184....
saw on carouhell selling at $20...
more den 10yrs liao... i rather throw den trying to revive it
gotch fweeling huan:frown:
coyote
what is the conclusion after 8 pages?
Thus my answer at post #42.
Get this from Malaysia and send to a friend with a Malaysia address...
https://shp.ee/r7su6f8
impossible to get them at such price in Singapore. Not to mention, it's Gigabyte motherboard, best of the best in reliability!👍
Orcmors
I had this problem. It was a new case and PSU with an old mobo and CPU. The leds would light up and the fans starts to spin before it shuts down without even making it to BIOS. Anyway, in my case it was the front panel USB. With it unplugged, I could boot normally. So I took a flash drive and plug it in to the front ports a couple of times and that fixed it. I'm guessing some manufacturing debris got into the USB port shorting it out and the PC shut itself down upon detecting the short.
If I were you, considering the age of your PC, I would try going through the PC with canned air before doing anything drastic.
