[Help] My PC cannot start
testerjp
Got multimeter can check power supply.
But most likely TS don't have or don't know how to use.
Cheapest to test is cmos battery but you will also need to reset the bios iirc.
Can also try unplug all except one ram and hdd to see if it works. Using elimination method to see if those are the problems
These are the only things you can try easily.
Before that and if you are really noob in this.
Can consider do a video and WhatsApp show Nigel from sls. Video the main board reactions when you power on. Give as much details like the led got light up or not. I believe on the main board it may have some light
That guy heard is an honest folk. He from experience should be roughly can tell if it's cmos, mobo or psu. Mobo issue can be very erratic one. So provide the mobo model if possible.
orpisia
Emeritus Honorary Member
Could be psu pai and not supplying power to either the 24v or 12v
12v is a must wor...
quickly plug it in and try!!!
it should be located at the top left corner of the mobo. it has 6pins and the connectors are 2x 3pins
As a general conclusion, if you can't even post bios, then it's either the motheboard or the psu. Since you are sure that the PSU is working, then only the motherboard remains.
Tried the spare PSU again
Plugged in both the 24 pin and 12V this time
Same thing
uselessbum
Same thing
The following is an experiment of someone trying to turn on a pc without cpu, ram and gpu.
Even without those components, the case fans (connected to the motherboard) should still be able to run after pressing the power button, assuming your PSU is ok as well. If case fans don't even move, then it's likely your motherboard.
orpisia
Likely motherboard if you are sure your PSU no issue. Ram spoil, your other components (gpu, fans, etc) should still be on. Probability of ram spoiling is very low that's why ram makers offer liftime warranty. Even if CPU spoil, all your other components should also still be on on.
Then is motherboard gg Liao.
Means the 12V on the motherboard is gg is it
Because using the original PSU, I just plug in the 24 pin and take out the 12V connector, it behaves this way
I plug in 12V also same thing
uselessbum
See my post above about trying to on without cpu, ram and gpu. Even if those components are not present, your case fans (connected to the motherboard) should still run when you press the power button. If they don't, I think can more less conclude it is motherboard issue, provided you are sure that the PSU isn't at fault.
articland05
what other components in ur mobo?
can remove all of them and try power on?
any gpu, sound card etc all remove
leave 1 stick of RAM
gilcrest
remove ram, graphic card, hdd from mb. put in new cmos battery, reset cmos. turn on power, should hear error beep or see error code due to lack of ram, hdd..etc
if nothing, then change mb.
Change MB a lot need to change also, assuming current is dated technology. OS also need to reinstall; unless it was on ubuntu
orpisia
See my post above about trying to on without cpu, ram and gpu. Even if those components are not present, your case fans (connected to the motherboard) should still run when you press the power button. If they don't, I think can more less conclude it is motherboard issue.
When I tried the spare PSU, the PSU fan was running when I pressed power button
TA200
When I press the power button,
The fan behind spins for 1 second then stops
No spooling up sounds of any kind like it's supposed to have
No beep sounds
What's the problem?
Test w another psu
uselessbum
No, I'm talking about psu fan. I'm talking about your case fan. If the case fan connected to the motherboard doesn't even run when you power on, then it is likely motherboard issue. Please see the two videos I linked in that post, they show that the person is able to switch on the case fans connected to the motherboard even without the cpu, ram and gpu installed.
orpisia
When I press power button, only the exhaust fan at the back spins for 1 or 2 seconds then stops
The other 2 fans in front never spin at all
uselessbum
Then I think can conclude is the motherboard issue. Look at the videos below, even without CPU, ram and gpu installed, the case fans (exhaust,etc) were still able to run non-stop because the psu and motherboard were ok. And since you have determined that the PSU is ok, the only logical remaining thing would be the motherboard since your case fans can't run continuously.
weiess
Motherboard up lorry liao..
Still under warranty RMA lor...
testerjp
But electrical issues may not fail alone. Electric surge could daisy chain and destroy more than the mobo. :(
I will probably change the psu too even if it appears working. :(
orpisia
Eh paisay sorry
The 2 front fans got spin up
Just that they didn't make noise when I pressed power button, so I thought they didn't spin
But they actually did, when I turned on my phone flashlight to see
uselessbum
Eh paisay sorry
When you say that the front fans spun up, was it only for a second then stop like your exhaust one or were they continuously spinning like the ones in the video? The key point to note is spinning continuously, not just for a few seconds.
testerjp
It still don't mean much.
The main board is connecting all the functions to work together.
If it can spin, means that route maybe okay.
It can also suggest that the psu can pass electricity, but how much is another question. :(
uselessbum
Earlier on we ruled the PSU out because he tried a different PSU on the same mobo and it was still the same issue. Of course, there is the possibility that both PSU also koyak but I think low chance ba.
orpisia
All 3 fans (1 exhaust, 2 fans in front) spin for 1 or 2 seconds then stop
