High fuel consumption
bendi85
My 2nd hand 08 lancer has abnormal high FC. Full tank 400km.
Everything else is stock and rev dont pass 3k rpm. Last major servicing 3 months ago. What can be done to solve this issue? Mine is a manual ride.
Engine overhaul?
Refresh ecu?
Cheepoozz
i was considering lancer before i got my manual avante in Jan.
Avante. FC around 12-13km/litre - tank is 53+- i can hit around 650-680km.
u should check if that is the norm? and how big is your tank? we cant tell when you only give indication of the 400KM and no idea how much petrol is used.
bendi85
Full tank I pump around 40l. I ask around usually people get 550km at least.
My mileage about 100k liao. O2 sensor need to change?
gohsj89
1) What is your tyre pressure? What size and profile?
2) always getting this fc or recently?
My auto vios is giving me below 12..
i pump 37L into my 45L tank and usually give me slightly over 400.
no i am not light footed.
i like to rev till 3k all these..
bendi85
I don't think tyre profile or pressure can affect FC till this bad.
I just got this car 3 months back and has always been this bad.
HeadQuarters
Avante has a 53L fuel tank, whereas Lancer has a 50L tank.
Low fuel indicator will light up when there are only about 10 litres of petrol left.
Bendi85 pumps 40L each time when he pumps full tank, and he gets 400km. About 10km per litre.
Cheepoozz, u mean u everytime run out ur tank then go pump 53L one shot? I think your low fuel indicator would have lighted up by ~ 520km. It's bad for your fuel pump if u run it empty to get 650-680km... :o
HeadQuarters
Which brand of petrol are u using? I think it matters.
I got my Civic for 2 months.
I pumped SPC98 for the first 3 tanks, mileage is only about 9.5km/litre.
The 4th and 5th tanks were V-Power and Shell 98, mileage up to 10.8km/litre.
Now I am trying out Caltex Techron 98 and see how :o
bendi85
Esso 5000.
Haiz my previous aveo got FC issue. Now change to manual lancer thought will be better. But still same! Argh...
q w e r t ii
avante 53L very likely on paper only, actual figure might be more
at 1/4 mark, i go jaybee pump til vomit can squeeze about 50L.
although i agree Cheepoozz way of calculation is inaccurate
ZhuTou!
Fc again :s13:
Last time ur aveo also fc problem :s13:
Have to see ur driving route also la
How much city/highway?
Try clear carbon, it works for my bravo
When i first bought it, fc 9.5 only no matter how i light footed
I clear and clear carbon, now around 11.x
Pump 50L get around 580km
Still trying to clear carbon from time to time
I got change my gear oil but not sure it helps anot
U can try lor
swissmade
Esso 5000.
Could be a whole range of issues. Your throttle body might need to be looked at? Air filter cleaned recently? Set your idling rate lower maybe?
Tyres can cause a lot of drag and increase fuel consumption.
The main killer, however, would be stop and go traffic. If you're clocking your miles on the expressways then you'll get better mileage.
If you think this car consumes a lot of petrol then further downgrade lor. Get a QQ? That will run on the smell of gas. Alternatively you could sell your car and take public transport.
HeadQuarters
I got DBS esso credit card lea..got 17% discount.
Shell use what credit card got discount?
I pump jb vpower racing also not much diff.
For Shell, u need the Shell Escape Card to get 10% discount, then depend on which UOB card u use, u get additional rebate ranging from 3-7%. So effectively is 12+% to 16+% discount.
For SPC, u need SPC&U Card to get 15% discount, then use POSB Everyday card to get another 3% rebate. Effectively 16+% discount.
For Caltex, HSBC, OCBC and SAFRA card give u 14% discount straight away.
Esso is the one I have yet to try. What credit card can I use?
swissmade
Fc again :s13:
U can try lor
No, changing gear oil only affects the lube in your transmission box - have you seen how dirty it gets after a few years? Small bits of metal from the gear meshes get chipped off and run with the oil - that's why you need to change it. But it won't affect fuel consumption.
HeadQuarters
Fc again :s13:
U can try lor
How do u clear the carbon huh? :o
bendi85
Fc again :s13:
U can try lor
Haha ya lor damn suay every time got FC issue.
I got Klear Karbon to clear liao lea..gear oil also change before.
I suspect the previous owner got do some mod and tuning.
